rev limit
Old Apr 29, 2007 | 01:09 PM
toughy v8's Avatar
Default rev limit
how can you rev a standard ls1 with arp bolts maybe?
Old Apr 29, 2007 | 01:32 PM
allngn_c5's Avatar
How high can you rev?? I don't think the arp bolts are the real decider here. It will be your valvetrain and cam combo.
Old Apr 29, 2007 | 01:51 PM
toughy v8's Avatar
do you think the standard components could handle 7k?
Old Apr 29, 2007 | 02:08 PM
hpjunky98's Avatar
no ... trust me on this one
Old Apr 29, 2007 | 02:14 PM
c0ncEpT's Avatar
Stock cam drops off after 6K so there should be no reason for you to rev the motor this high anyways. Stock valve springs cant handle 7K. There is not a single reason to rev a stock LS1 above 6200. 1. It wont make power, 2. It WILL break
Old Apr 29, 2007 | 05:26 PM
Starz T/A 17's Avatar
Very well said
Old Apr 29, 2007 | 05:41 PM
bww3588's Avatar
use your right foot on the accelerator pedal, or if under the hood, take your right or left hand and manually open the throttle using the throttle cam on the side of the TB.
Old Apr 29, 2007 | 07:14 PM
Fb0dy0nly's Avatar
Old Apr 30, 2007 | 06:19 AM
bluecamaroz28's Avatar
With ARP rod bolts, cam, springs and pushrods you can rev to 7500 if the cam doesn't drop off at that RPM.
Old Apr 30, 2007 | 09:29 AM
tim99ws6's Avatar
i revved my dead stock Ls1 to 6600 for 2+ years with no problems whatsoever. And, the theory that a Ls1 stock doesnt make power beyond 6200 is a farce(sp?). It all depends on where you drop revs when you grab the next gear. For me, i picked up mph and dropped tenths by revving the extra 400rpm.
Old Apr 30, 2007 | 02:47 PM
c0ncEpT's Avatar
With a large cam, Rod bolts, and good springs I would not feel to bad spinning to 7.2K if the cam makes power there. But stock components can not handle 7K+
