Puzzling problem - please read!
Old Oct 27, 2007 | 10:22 PM
  #181
flyin ryan's Avatar
Good to see you have it apart.
Now the big question is -- do you have any idea as to why the valves got bent ?
That has to be resoulved before it goes completely together.
I would also be sure the shop checks the intake valves as well while they have the heads.
Good luck .
Ryan
Old Oct 28, 2007 | 12:54 PM
  #182
Tainted's Avatar
Taking the heads to the machine shop tomorrow.
Front cover is off, and the ****** timing was off by a **** hair
I just hope my pistons will be ok, no cracks, but maybe i can sand any sharp edges off where the valves hit.
Old Oct 28, 2007 | 01:48 PM
  #183
ArcticZ28's Avatar
How many teeth off?
Old Oct 28, 2007 | 01:49 PM
  #184
Tainted's Avatar
i think just 1. I dont have the oil pump off to be sure, but it looks like just like 1 tooth, or even a half of one
Old Oct 28, 2007 | 08:18 PM
  #185
crainholio's Avatar
I'm still 99% sure he's got a multi-keyway timing set and didn't align the right crank gear mark with the right cam gear mark.
Old Oct 28, 2007 | 08:21 PM
  #186
Tainted's Avatar
i might crainholio, im having teddy come voer and actually degree that ****** in instead of dot-to-dot or w/e and have him put the timing on. He thinks whenever we were turning it over, it was such a small **** hair off it eventually just threw it all outta whack.
Old Oct 29, 2007 | 04:05 PM
  #187
Tainted's Avatar
ok new phone, so that means I have pics once again. So here they are, as you cans ee they arent bad, and the more I felt of them the more i realised its not really anything at all. I took my heads to the machine shop and questioned him about the pistons and he said they will be just fine.
Old Oct 29, 2007 | 04:23 PM
  #188
WS6NIGHTMARE's Avatar
Ive seen worse....Have you adjusted the timing yet? Get a clean shot of the gears if you havent so we can get a look at it.
Old Oct 29, 2007 | 04:26 PM
  #189
Tainted's Avatar
no not yet jason. im gonna let teddy dealw ith the oil pump ick up tube and cam timing so ive not even unbolted the oil pump yet.
Old Oct 29, 2007 | 04:40 PM
  #190
Smokin87TA's Avatar
Restricted User
Originally Posted by Tainted
Heads are OFF. The exhaust valves are bent. The intakers are all fine, however, theres some indentation on the pistons, not to horrible, no cracks, but you can feel the spot where they hit.
Those are definitely not the exhaust valves, they are the intake valves that hit the pistons. The larger valves are intake, smaller are exhaust. The larger ones are the ones that hit the pistons.
Old Oct 29, 2007 | 04:42 PM
  #191
Tainted's Avatar
grrr woops my bad intake valves, having a rather busy day
Old Oct 29, 2007 | 04:43 PM
  #192
Smokin87TA's Avatar
Restricted User
Hey no problem just thought i would clarify, good luck getting it figured out. Tim
Old Oct 29, 2007 | 05:05 PM
  #193
Tainted's Avatar
thank ya tim I may end up needing it.
Old Oct 31, 2007 | 06:38 PM
  #194
litle88's Avatar
Good luck lil bro!!!
Old Oct 31, 2007 | 11:36 PM
  #195
98Camarod's Avatar
I'd vote for the multi keyway as mentioned before. I got rid of that piece of **** and got a single cloyes hexajust. There was only one non adjustable double roller that I had seen for rollmaster. Was the crank gear in two pieces? If it was, then it is most likely the adjustable one and thats how you bent the valves. One tooth isn't going to make it bend valves, having it on the wrong keyway will though. Good luck. I fucked up my crank threads and had your same feelings towards the car. Now its fixed and me and my car are cool again.
Old Nov 4, 2007 | 08:01 PM
  #196
98Camarod's Avatar
Is there any update?
Old Nov 4, 2007 | 09:36 PM
  #197
Tainted's Avatar
nope heads are still at the machine shop
Old Nov 10, 2007 | 07:58 PM
  #198
litle88's Avatar
Hey Charles, how's everything going?
Old Nov 10, 2007 | 08:01 PM
  #199
Tainted's Avatar
things are doing well now actually. We get to pick up my heads monday from the machine shop with all new valves and seats. Gramps agreed to let me and dad get some ARP head bolts so we can bypass the whole torque sequence and turning this and that 56* yak yak yak ****.
Dropping the oil pan tomorrow and Teddy is comming over to do a full cam degree and get this thing perfect, then I'll be ordering the bolts and gaskets monday.
Old Nov 10, 2007 | 08:09 PM
  #200
litle88's Avatar
Nice!!!
I still want a dam video of the start up, its been a year now!
