Puzzling problem - please read!
Old Nov 10, 2007 | 10:22 PM
  #201
LilJayV10's Avatar
Man it sucks that it happened. I built a 406 that I installed the 2nd ring upside down on all the pistons. I read the instructions wrong. I had to take it back apart. That was three years ago. Hopefully it will be running this winter.
Did you ever find out what caused the valves to bend? By that pic the edge of the valve didn't hit the piston it was the whole damn valve.
I personally don't think you can bend a valve just turning it over by hand. Especially with a hydraulic cam. I could be wrong though. Good luck.
Old Nov 10, 2007 | 11:23 PM
  #202
socmguy's Avatar
Restricted User
Glad to see that thing's getting unfucked Charlie. Let me know when that bitch is on the road! oh, and btw, FFA are a bunch of queers.
Old Nov 10, 2007 | 11:28 PM
  #203
Tainted's Avatar
Im happy to almost have it back. The last time I drove it was when I put in my longtubes and borla, it was loud back then with an open plate, now tis gonna be REALLY loud
Old Nov 11, 2007 | 07:35 AM
  #204
crainholio's Avatar
Originally Posted by Tainted
Gramps agreed to let me and dad get some ARP head bolts so we can bypass the whole torque sequence and turning this and that 56* yak yak yak ****.
Countdown to blown head gaskets and next round of "Another Puzzling Problem!1!11!!one!"
10...9...8...7...
Old Nov 11, 2007 | 09:28 AM
  #205
socmguy's Avatar
Restricted User
10...9...8...7...
BwaaaahHAHAHAHAHHAHAHAHAHA!!!!
Old Nov 11, 2007 | 10:01 AM
  #206
Tainted's Avatar
aww that was low.
No more **** ups from now on, or if you feel that you can do better, you can come help brandon
Old Nov 12, 2007 | 09:45 AM
  #207
cam's Avatar
cam
From those pics it looks like you used an air grinder and scotch wheel to clean the deck surface on your block? If so on aluminum that can wreak havoc on it ( as in high and low spots ) and cause premature head gasket issues. If you did clean it that way I would use fel pro graphite head gaskets and I also highly recommend you spray the block side of your head gaskets with a few coats of this stuff right before you bolt them up.
http://permatex.carshopinc.com/produ...id/42287/80697
You absolutely need to follow torque sequences as well or your in for bigger problems. Also be very very sure you have cleaned out all the coolant from the head bolt holes or you can cause hydraulic locking and crack your block. Aluminum blocks are not nearly as forgiving as iron. Finally for what its worth I'd also sell your roll master double and get a single LS2 chain. Cheap, tough, and easy to install properly. Good luck
Old Nov 12, 2007 | 11:37 AM
  #208
WS6NIGHTMARE's Avatar
Umm, Charlie....I dont know where you got the idea of bypassing torque sequence, but its a no-no.
Old Nov 12, 2007 | 12:07 PM
  #209
ArcticZ28's Avatar
x2. Where did this idea come from? Using ARP studs just means different torque sequence and intervals, not bypassing anything.
Old Nov 12, 2007 | 12:59 PM
  #210
88blackgt's Avatar
wow maybe you shouldnt be doing this. "bypassing the torque sequence?" are you out of your mind?
Old Nov 12, 2007 | 03:12 PM
  #211
Tainted's Avatar
hmm I think I must have said that completely wrong.
Lemme try and think of a better way of saying this.
Instead of the stock bolts like torque all botls to 22ft lbs, then torque bolt #8 and 10 to 50 ft lbs, then torque the other to say 66ft bls then go voer thema gain and turn it 50* yak yak yak. You just go in order of what bolt tightens first and you toqrue it down right then, no going back over the same bolt a dozen times.
Old Nov 12, 2007 | 03:26 PM
  #212
SoCal01z28's Avatar
you still have to torque ARP in stages just like the stockers, you just don't have to torque to yield...
Old Nov 12, 2007 | 05:22 PM
  #213
88blackgt's Avatar
yup. maybe you should take the car to someone.
Old Nov 12, 2007 | 05:36 PM
  #214
Tainted's Avatar
never.
Sorry, wont happen, not when im capable of doing this myself. I thought the ARP's you just torqued down in order and you jsut didnt have to go back down over them. Its ok though, I would have read the directions either way and saw what needed to be done.
Old Nov 12, 2007 | 05:37 PM
  #215
Tainted's Avatar
Oh yeah, heres some pics of my heads Hellllo titanium valves
Old Nov 12, 2007 | 05:54 PM
  #216
SoCal01z28's Avatar
never.
AND.... whats 10 more minutes in the whole scheme of things to have to re-torque or even have to torque to yield bolts? if your really that worried about shaving that much time off of the build you've got things totally backwards. + ARP's don't come with instructions, just a table on the box that says suggested torque rating for each bolt size....
the only reason you should be going to arp's anyways is for the ability to re-use them, or for the added cylinder pressures they can handle with power adders, but your mechanical apptitude + power adders would start a whole new 15 page blockbuster thread
Old Nov 12, 2007 | 06:07 PM
  #217
_JB_'s Avatar
Man I wouldn't torque them down to the max on the first and only pass. Try it on your rims and see what happens. Same concept applies here.
Old Nov 12, 2007 | 06:09 PM
  #218
crainholio's Avatar
never.
And when will that be?
Old Nov 12, 2007 | 06:25 PM
  #219
Tainted's Avatar
I guess we'll jsut have to wait a lil while longer and find out now wont we?
Anywho, see I've already got the ls1howto guide that has the sequence n all that ****. Still shouldnt be to complicated, even if I do gotta do the sequence.
Old Nov 12, 2007 | 06:31 PM
  #220
crainholio's Avatar
Still shouldnt be to complicated...
You said that last time around. Right up there with "Y'all watch this!!!" in famous last words.
