What sensors are these (Prof. Products mani questions?)
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
What sensor is the round one on the back by my intake mani.?
Also I dont think my engine builder installed any knock sensors on my engine, if he did were would the wiring come out? I have a Painless hotrod harness and cant find the knock sensor wiring. What a clown if he didnt, im so mad I have to take the mani off. I just got all the acc and stuff on.
Were can i get a MAP and some knock sensors? Engine is from an 03 vette, thats what I was told.
What are these sensors? I think on my intake mani the MAP goes in the hole in the center there on the intake, also what vaccume lines go to the back of my mani?
![](https://i128.photobucket.com/albums/p176/ranger2339/axel020.jpg)
Thanks
Josh
Thanks
Josh
1. the knock sensors do go under the intake in the two holes in the valley cover, the connector is an odd shaped circle ill find a pic in a min.(have to log into gm dealerworld)
2. the map goes in the center hole, and on stock ls1,6 intakes their is one Vaccum port that goes for your ac, and the other one is for the brake booster, youll need some fittings, i found some at a hardware store for like 2 bucks, they look like freez plugs with nipples.. youll need a big one for the booster and one small one for the ac side
3. you can get the sensors on ebay fairly cheap!
and finally i noticed that you dont have block off's on the rear coolant crossovers, you ll need some,
You guys are the best, thanks allot!! Just took of my mani. and there is no damn knock sensors, I looked on Ebay and found these. Will they work for me?
Harness for 98-02 LS1 F-body.
http://cgi.ebay.com/ebaymotors/98-02...ayphotohosting
Knock sensors I would use with that harness? Or does it even matter if its for a LS1/6 Vette or F-Body etc.?
http://cgi.ebay.com/ebaymotors/98-02...spagenameZWD1V
Only question is about my year engine, the guy I got it from (I was in Iraq when I bought it) said it was a LS6, well he had me convinced it was a LS6 also, as I didnt know better back then and was far away. Then I got smart and looked at picture my builder sent me and the heads numbers were 241 and not 243, I noticed it wasnt a LS6 but a LS1. Now how do I tell what year engine I have? The harness is a Painless Hotrod for a LS1/6 (I think) the PCM says on it that its tuned for a LS6 with cam (had the guy tune it when I still thought I had a LS6) I bought all this stuff a year ago when I was overseas and now am forgetting what it all is and what its all for.
So recap.
How do I tell what year engine I have?
Does it matter what LS1 (either Vette or F-Body) knock sensors I use?
You guys are the best.
Also since I have you guys here, what goes here. Its a hole by the starter, with the paper towel stuffed into it. Goes into the oil pan?
![](http://i128.photobucket.com/albums/p176/ranger2339/axel029.jpg)
Pics of PCM maybe you can tell what year it's for from the numbers?
Numbers are, from top to bottom of label.
Serv. No 12200411 DLAC
*86DLAC911008VZY7*
HDW No. 09386530
![](http://i128.photobucket.com/albums/p176/ranger2339/axel032.jpg)
Here is a pic of the knock sensor female connector form my harness, what year does that look like?
![](http://i128.photobucket.com/albums/p176/ranger2339/axel031.jpg)
Sorry for all the questions, just want to get all my ducks in a row and get this thing done before my next damn deployment.
Thanks a ton!
Josh
So recap.
*86DLAC911008VZY7*
HDW No. 09386530
Thanks a ton!
Josh
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
So recap.
Don't know how to tell the year, but look here and it will help you determine if it's an LS6 block or not:
https://ls1tech.com/forums/showpost....86&postcount=8
Doesn't matter as long it's the 2nd design sensor. GM part # 12589867 - Sensor. Works with LS1 and LS engines.
GM part # 12601822 - Wire Harness
No clue
*86DLAC911008VZY7*
HDW No. 09386530
No clue
No clue
Thanks a ton!
Josh
No clue
*86DLAC911008VZY7*
HDW No. 09386530
No clue
No clue
Thanks a ton!
Josh
Thanks!
So I might have jumped the gun a bit, I bought two of these sensors. In the add it says there the early model sensors, but says they fit all LS models pretty much? Are these good to go or no?
http://cgi.ebay.com/ebaymotors/ws/eB...263119654&rd=1
Also will this MAP work for me? I think it will, just want to confirm.
http://cgi.ebay.com/ebaymotors/OEM-M...spagenameZWD1V
Thanks
Josh
Thanks
Josh
Do you have to fab those up yourself, or does somebody make them?
Also will those knock sensors plug into the new harness? I have the GM#12601822 harness. I guess I will see when they get here, I hope they fit. I need to get this thing going.
Thanks guys!
Josh
It would be tough to make them. Most sponsors here carry the kit, Thunder Racing and Texas Speed are 2. Most people block off the back 2 and the front 2 are connected together with a pipe and a tee goes to the neck of the radiator.
http://www.texas-speed.com/shop/item...d=242&catid=12
Check out this thread for the seals and plug part numbers listed individually and for a pic of what they look like installed. Did you ever figure out the knock sensor connnector issue?
Edit...looks as though the part number changed for just the plugs...it's 12563325 and not 12562788.
https://ls1tech.com/forums/showthrea...ferrerid=13535
Awesome! You guys are the best.
I'm still waiting on my knock sensors to get here, then I will see if the work. I think I wiil be ok.
Next time I am just buying a complete engine and not just a bare block, to peice together. ha. Lesson learned the hard way...
Thanks
Josh
Thanks
Josh
