Which lifter Trays?
Old Nov 18, 2008 | 07:59 AM
PewterMNZ's Avatar
Default Which lifter Trays?
I have done a lot of reading about lifter trays and I guess I am confused on which ones to actually get. I am doing PRC 5.3 2.5 heads over the winter, and I need to know which trays to go with , LS1, LS2, LS7? What are the differences between them?
My car has 24,000 miles on it.
Thanks,
Old Nov 18, 2008 | 08:10 AM
JBIRD02's Avatar
LS1 or LS2 style will work in an LS1, but only LS2 trays work in LS2's. This is because there is a notch in the LS2 style that must be there to clear on the LS2 block, however, since there is no need for a notch on the LS1's, either style will work. So, get whichever one is cheaper.
Old Nov 18, 2008 | 12:35 PM
Justin93's Avatar
The ls2s are supposed to be marginally stronger so if your gonna change em you might as well get the better ones, either way there only 7.50 a piece anyway!
Old Nov 18, 2008 | 12:39 PM
PewterMNZ's Avatar
Cheaper if you work for a dealership
Old Nov 18, 2008 | 01:30 PM
Justin93's Avatar
This is true lol
Old Nov 18, 2008 | 04:13 PM
samh_08's Avatar
Anyone know if a 05 LQ4 has LS2 trays already?
Old Nov 19, 2008 | 09:52 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The '05 iron block would have had the Gen3/LS1 trays from the factory. But as stated above, you could use the LS2 trays if you'd like!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 19, 2008 | 11:51 AM
samh_08's Avatar
Do you think it is wise of me to do this with the H/C combo im getting from you guys? What is the benefit of the LS2 lifter trays?
Old Nov 19, 2008 | 11:53 AM
PewterMNZ's Avatar
+1 I will be ordering heads not to long from TSP as well. Would like to know the benefits as well.
Old Nov 19, 2008 | 01:32 PM
I have not seen any real advantage of the LS2 tray over the LS1 trays. On the internet, there is a theory that the LS2 pieces are stronger, but I doubt that came from any real testing or solid data.
They are very inexpensive, so I think it is a good thing to replace them when you've got the heads off. I've talked to way too many people who had stock trays crack or whatever, and have to replace alot of parts when the lifter spun in the tray.
__________________
