View Poll Results: Would you install an "off-the-shelf cam" dot-to-dot?
Yes
80.53%
No
19.47%
Voters: 113. You may not vote on this poll
Dot-to-dot.. or not?
Old Jan 4, 2009 | 07:25 AM
04gtod's Avatar
The last cam that I just installed was off by 2 1/2 degrees. If you are planning a heads/cam setup and trying to get optimum SCR and DCR and peak power, changing the cam advace 2-4 degrees changes the valve events you so carefully planned out. So yes, I would degree the cam.
Old Jan 4, 2009 | 01:06 PM
chrs1313's Avatar
Originally Posted by 99blancoSS
Cams are not ground perfect at all. We've seen them be more than 4* off and that was with a very popular off this shelf cam on this site.
Not degreeing it in can account for why one person see's more power than another with the same combo. Its not that dot to dot is incorrect, but unless you check you dont know where your at.
I've seen some shops who dont check and then there are those who wont put a cam in without checking. We always check, it's easy enough and performance can be effected by it. How much it's effected all depends on how far its off. To some its minimal to others minimal is a world of difference. (Some guys spend hundereds to chase that 5 extra ponies, some guys dont think it matters.)
agreed well said
Old Jan 4, 2009 | 02:41 PM
RyderTA's Avatar
You guys are making me want to go back in and degree my cam! Damn you guys!
Old Jan 4, 2009 | 07:05 PM
GMmexican's Avatar
My custom grind from thunder racing was suppose to be-232/232 .612"/.604" 110LSA +2
But luckily tr puts all ther cams on the cam doctor and actual cam specs came out to.
233.2/232.5 .613/.602 110.5 LSA
Old Jan 4, 2009 | 08:43 PM
TORCHD 02 TA's Avatar
yeah i know i was thinking the same thing
Old Jan 4, 2009 | 08:49 PM
JPH's Avatar
JPH
Originally Posted by PowerTalk
Im buying an off-the-shelf cam and was starting to wonder whether I should just spend the extra dollars and get a workshop to install it.
I called THREE workshops and they ALL said they'd just install it straight up and not degree it in. I just had to give them the part number of the cam and springs I wanted and they'd supply the pushrods, timing chain and tune.
The cam is a Comp 54-456-11 - 219/227 .607/.614 112LSA
w/ Patriot dual springs
Would you install an off-the-shelf like this one dot-to-dot?
Main reason for a workshop was I didn't have the equipment to degree it in, if they won't even bother, I'll just do it myself then
If you don't have an adjustable t/c set, I would just install it straight up. Most of those shelf cams have 4* of advance built into them anyways. It's always a good idea to degree it, but if you don't have the time or proper tools, your kinda stuck. Just my 2 cents.
Old Jan 4, 2009 | 09:00 PM
HavATampa's Avatar
How much does a "workshop" (not sure what that term even means...lol) charge to install a cam in these cars? The money he is saving doing it himself would be more than enough to cover the cost of a degree kit. And then if he see's he needs an adjustable t/c set, he can purchase one and still be ahead of the game IMO and learn something along the way.
Old Jan 4, 2009 | 09:31 PM
RyderTA's Avatar
I had a friend tell me a local shop quoted him $800 to swap a cam in his GTO, what a rip!
Old Jan 4, 2009 | 09:37 PM
JPH's Avatar
JPH
$550 and up usually, and I doubt that includes them degreeing it. I charge more myself for doing that.
Old Jan 5, 2009 | 06:08 AM
eallanboggs's Avatar
So you degree the cam, but if you don't have an adjustable timing you're just spinning your wheels. Most of the adjustable timing sets sold by sponsors on this site have fixed 2 degress increments of advance and retard. If you want more precise adjustment you have to go to an infinitely adjustable system like Jesel. Is it worth it? NASCAR thinks so.
Old Jan 5, 2009 | 06:26 PM
vsocks1's Avatar
Cloyes Hex Adjust -6 to +6 in fractions of a degree!
Old Jan 5, 2009 | 10:55 PM
  #32
LS1nut377's Avatar
when i put my cam in im doing it dot to dot. dont have the money to degree it,but you know cam is a cam and its going to run good after its tuned. dont do dot to dot and you might regret it.good luck on the install.
Old Jan 5, 2009 | 11:07 PM
  #33
HavATampa's Avatar
Question
lol! Did you read anything in this thread but the OP's first thread? Not telling you that you have to degree your cam, but your statement of "a cam is a cam" is not true at all. There is proof in this thread from knowledgle people that do this kind of work on a daily basis (not me) and see the errors in cam manufacturing and errors in dowel placement, etc. If these issues exist and you don't catch them, no tune in the world will make it right.
Old Jan 6, 2009 | 05:58 AM
  #34
jeejee's Avatar
my lpe gt2-3 cam when installed dot to dot was 2 degrees off.
this not neccesarily was just the cams fault.
But all little things added up : manufacturer tolerances from chain , chain sprockets, crank sprockets, deck height etc .
Old Jan 6, 2009 | 11:56 AM
  #35
slow ride 02's Avatar
For years, I would just "shove them in dot to dot" and only check p/v with no problems. Intill one time I had just a lazy pos. Checked it and it was 16 degrees retarted. Needless to say I always check them now. So I say check it or chance it, your choice.
Old Jan 6, 2009 | 02:17 PM
  #36
Degreeing a cam is "Fine Tuning" where you at least have to be in the ball park to start with. This assumes all the parts and pieces were manufactured to tight machining specs. "16 degrees retarded" isn't even near the ball park let alone inside of it. All the degreeing in the world isn't going to get rid of that much of an error. Something major is wrong when your starting point is that far off. This problem has to be corrected before the degree wheel goes on. If you happen to get extremely lucky(powerball lucky) and the degree wheel says you're exactly 2 degrees off either advance or retard you can adjust for that with one of the popular timings sets that has multiple keyways. If you find you're not exactly 2 degrees off you're going to need one of the more expensive Jesel or Cloyes sets to take advantage of the precision adjustment degreeing a cam provides for.
Old Jan 6, 2009 | 02:59 PM
  #37
NemeSS's Avatar
i installed a former site sponsor cam in friends car a time ago, cam was ground incorrect. i installed dot-to-dot, something i nver do even with sbc cams.
long story short, made me look like i didnt know what i was doing, and cost me to help replace his motor.
former sponsor didnt do anything to help, them
they are no longer around
good riddance
Old Jan 6, 2009 | 06:23 PM
  #38
WS.666's Avatar
Where can I get a cam degreed? Can I rent the tool from Autozone? I don't even know what it looks like...
Old Jan 6, 2009 | 06:58 PM
  #39
nmcqueen469's Avatar
Read through this thread: https://ls1tech.com/forums/generatio...l#post10748838
Old Jan 7, 2009 | 11:37 AM
  #40
01ssreda4's Avatar
i installed my 224 cam dot to dot and didnt check ptv. i should be banned ha ha.
