View Poll Results: Would you install an "off-the-shelf cam" dot-to-dot?
Yes
80.53%
No
19.47%
Voters: 113. You may not vote on this poll
Dot-to-dot.. or not?
Old Jan 7, 2009 | 01:22 PM
  #41
slow ride 02's Avatar
Originally Posted by slow ride 02
For years, I would just "shove them in dot to dot" and only check p/v with no problems. Intill one time I had just a lazy pos. Checked it and it was 16 degrees retarted. Needless to say I always check them now. So I say check it or chance it, your choice.
That thing was so retarted, I had to advance the crank sprocket one tooth and then retarded it 4 deg with a with a crankshaft key just get it "stright up". One again check it or chance it. So you have to ask yourself one question " do I feel lucky?" Well do you punk? (Clint Eastwood line) lol
Old Jan 7, 2009 | 02:06 PM
  #42
99 Black Bird T/A's Avatar
Everything that goes into an engine should be checked and recheck to make sure it's right.
Degree the cam.
Assuming something is right without checking it just sets one up for problems.
Sure it's right 99.9% of the time...it's those .1% that add up and eventually burn you if you don't check everything!
Old Jan 13, 2009 | 01:13 PM
  #43
RedRocketZ28's Avatar
Originally Posted by 01ssreda4
i installed my 224 cam dot to dot and didnt check ptv. i should be banned ha ha.
If you should be banned then I should be castrated for installing my custom 231/232 .612/.592 111+4 cam dot to dot. I should have degreed it in as the car is not making near the power it should. Figured everything was good to go since I had the cam doctor sheet and all. I think I'm goin to tear it apart this spring just to make sure it is installed correctly.
Old Jan 13, 2009 | 04:51 PM
  #44
chrs1313's Avatar
yeah you are pretty close i bet...my 230/230 .613/591 111+4 was at .072 on the intake...installed right...if you are off by a couple degrees you could be really close...
Old Jan 13, 2009 | 05:27 PM
  #45
12secSS's Avatar
I would say it really depends on the application. If it is a race only or all out HP setup, then yes degree it. If it is just for a street application that street races (not for money) or is daily driven, then no. All of you who say every cam install should be degreed, did you also check to ensure your primary lengths on your headers were optomized and did you alter the collector length to where your application needed it or did you just bolt-on a set of off the shelf headers? What about your intake, did you install an off the shelf intake or did you tune the runners and plenum volume? Interesting! I bet most did not, only those seeking that last 5 hp, which as I said ... it depends on the application.
Now on big(ger) cams I would definately at least check PTVC.
BTW, to me degreeing a cam is not checking the advertised specs (int dur./exh dur., LSA), but rather the valve timing events (IVO, IVC, EVO, EVC), that tells you more (clearer) about the cam.
Old Jan 13, 2009 | 07:58 PM
  #46
TORCHD 02 TA's Avatar
Now i am starting to wonder if i should have degreed my 228/232 .588/.595 110+4 cam
Car rns VERY strong though.. Any ideas?
Old Jan 13, 2009 | 09:41 PM
  #47
Nitroused383's Avatar
What I want to know is what adjustable timing set everyone recommends? I know the double rollers do not fit with out griding your timing cover. So what is a good setup to use, single roller adjustable or dual roller if the clearance thing is no big deal. Also at a decent price.
Old Jan 15, 2009 | 06:43 AM
  #48
chrs1313's Avatar
how else would you know if your cam is cut right without degreeing it, most sponsors do not have the cam doctored to make sure it is cut right...
if your cam has been proven to be cut right then i agree dot to dot is ok...otherwise it needs to be checked by degreeing it, or as you said checking the valve events...
Old Apr 29, 2009 | 08:12 PM
  #49
6.0mustang's Avatar
it doesnt matter weather your dot to dot or both dots up. the cam turns half the rotation as the crank. i could careless about degreeing a cam. the motor isnt going to last long enough in my hands to matter. Turn up the boost
Old Apr 29, 2009 | 08:53 PM
  #50
SweetS10V8's Avatar
Originally Posted by 04gtod
The last cam that I just installed was off by 2 1/2 degrees. If you are planning a heads/cam setup and trying to get optimum SCR and DCR and peak power, changing the cam advance 2-4 degrees changes the valve events you so carefully planned out. So yes, I would degree the cam.
These statements humor me...
Your camshaft doesn't stay exactly where you install it. There are many forces changing many things, the cam deflects, the cam doesnt turn exactly 1/2 the speed of the crank in a smooth fashion, its rotation speeds up and slows back down independantly.
All your timing points/valve events, and even durations change dramtically at speed (RPM) and you have no way of measuring or knowing what is REALLY happening... All these super calculations of dynamic compression and getting everthing to the Nth degree makes you feel good, sure. Its making it the best you can, also correct. But is is not black an white the way people try to make it sound.
Old Apr 29, 2009 | 09:01 PM
  #51
LS1-NAVY's Avatar
so if i got my cam from thunder racing and they doctor it and it is right i would be ok to install dot to dot
Old May 1, 2009 | 09:00 PM
  #52
01redws6ta's Avatar
TorchD02TA, I would not waste the time rechecking your cam...it put down some good numbers...similar to mine. I'd bet it is pretty much right on the money. BTW, the car sounds great and looks badass...well done! Did you ever get a set of 4.10's?
Old May 3, 2009 | 03:15 PM
  #53
smokin2002's Avatar
ive been going 9's with my BBC on Dot to Dot with a .700 lift cam, and my PTV was seeing if the motor would spin over sometimes you just have to live a lil
Old May 3, 2009 | 03:44 PM
  #54
383lt1impala's Avatar
Like when my builder refreshed my ls1 I bought a brand new ms4. And it ms4 is .649 intake lift and .609 exhaust. And it really had .640 and .614 exhaust. The duration was off by one or two degrees the lsa came as said (112). But he said good thing it had smaller lift cuz .650 if the MAX lift I could have gone. So I say degree it!!!!!
Old May 7, 2009 | 02:57 PM
  #55
Ed Curtis's Avatar
Cool
Dot to Dot explained
Old May 8, 2009 | 09:18 PM
  #56
VeTTeMaNC486's Avatar
TSP tsunami 235/240 .647/.609 111lsa Dot to Dot. Spun it over by hand to check PTV clearance.
Didn't have an adjustable timing chain and was using a budies garage so it wouldn't have mattered either way.
When I do my underdrive pulley and go back in there to do a timing chain I will probaby degree it for piece of mind.
