View Poll Results: What Will My RWHP be?
360-370 RWHP
2
5.00%
370-380 RWHP
1
2.50%
380-390 RWHP
5
12.50%
390-400 RWHP
15
37.50%
400-410 RWHP
10
25.00%
410-420 RWHP
7
17.50%
Voters: 40. You may not vote on this poll
college ms3 build
Old Feb 4, 2009 | 12:29 AM
The Cook's Avatar
Default college ms3 build
As racing season approaches I got the bug again to start working on my car. This time I have the money to do it though so ill list below what my plans are. Im open to any suggestions/comments. Just wanna make sure I know what im doing since im use to gen I sbc's and am still somewhat noobish on the LS1's.
TSP MS3 cam 112LSA PRC dual spring/pushrod package
LS6 Oil Pump (stock or ported from TSP?)
LS2 timing Chain
LS6 Intake
Pacesetter 1 3/4" ceramic coated longtubes w/ORY
Dual QTP cutouts
Stock Rockers... or should i get something else?
New stock LS1 water pump
(holding out hope on the stock clutch and rear for now )
thats the list so far... let me know what im forgetting. as for the tune I was just going to do a mail order TSP tune... unless anyone can reccomend a good place I can have it done in either Peoria IL, the Quad Cities, Springfield IL, or Quincy IL area. The closer to Macomb IL the better! and not chicago. also hoping to stick with the 26# stock injectors or should I get bigger ones?
thanks for the info!
P.S. heard some rumors about TSP doing a tax season sale possibly...?? any truth to that? Like the title says... college... so if ive got an oppertunity to save i gotta look into it! Thanks
Edit:
UPDATED LIST:
TSP Ported LS6 Oil Pump
LS2 timing Chain
LS6 Intake
Home Ported TB
Stock Rockers
36# injectors
LS7 Clutch/Pressure Plate/Flywheel
New Slave Cyl
The Build Starts on the 4th page
Old Feb 4, 2009 | 01:28 AM
conde'strans's Avatar
Sounds good but I would definitely go with bigger injectors!
Old Feb 4, 2009 | 01:34 AM
BlkBird2000's Avatar
Stock injectors won't do?
If you want a tune and you're near the St. Louis area, PM. I know a good tuner!
Old Feb 4, 2009 | 07:49 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Yes TSP is running a sale right now. The stock clutch won't hold for long, so it should be on the list as well
https://ls1tech.com/forums/sponsor-s...xas-speed.html
Old Feb 4, 2009 | 02:31 PM
The Cook's Avatar
thanks. I saw the lower prices on TSP's site but i didnt think of it being that sale...
anybody make a reccomendation on injectors? Clutch I was thinking either LS7 or Spec stage 2 or stage 3... guess while im in there i might as well do it...
Old Feb 4, 2009 | 03:42 PM
Z28/2002's Avatar
Get a set of 42# injectors that way you will have room to play.
Old Feb 4, 2009 | 04:26 PM
IWGF's Avatar
Your stockers will hold up... Buy a clutch though... My car is hardly modded and that ****** is already givin on me...
Old Feb 4, 2009 | 04:40 PM
The Cook's Avatar
how bout these?
http://cgi.ebay.com/ebaymotors/42-In...Q5fAccessories
are they junk cause theyre so cheap? or do I gotta spend the big dollars on the bosch ones or something?
Old Feb 4, 2009 | 06:45 PM
SOMbitch's Avatar
Fluids, gasket set, balancer bolt, and plugs.
Stock rockers are fine.
You should be ok on injector's too but 36/42#'s won't hurt.
If your gonna do WP too look at Edelbrock or Evans. Both flow more.
Old Feb 5, 2009 | 12:35 AM
Z28/2002's Avatar
Check the For Sale section for some injectors. I picked up a set of SVO 42#'ers for $300 but that was two years ago. Might be able to find some a little cheaper
Old Feb 5, 2009 | 06:55 AM
vsocks1's Avatar
You can buy new Ford SVO 42#'ers for less than $300 now!
Go to buy ford racing and they are $289 with free shipping!
Old Feb 5, 2009 | 09:32 AM
gayslowassNALSjunk's Avatar
Look for stock GTP injectors. At ls1 fuel pressure they are rated at #41s I believe. All you have to do is go in and change the flow rate in HPT.
Old Feb 5, 2009 | 10:07 AM
The Cook's Avatar
hey yea thanks... that was my next question do i need a pump... guess not!
Old Feb 5, 2009 | 12:46 PM
Berz28's Avatar
i'm doin a very similiar build on my '98 z28, not sure which cam yet but something very close to what youre lookin at. i'll be using 36# FAST injectors. i'll also be using the stock rocker arms but since my motor had 140k+ miles on it so im gonna sent them to harland sharp to have rebuilt.
Old Feb 5, 2009 | 01:23 PM
SuperSlow02's Avatar
lot of c-dale people slappin the ol bump sticks in
Old Feb 5, 2009 | 01:39 PM
ItsNotStock's Avatar
There is someone selling a brand new LS7 clutch kit at half of the price in the for sale section. Should handle your mods just fine.
You can buy a stock LS6 and port it yourself in five minutes. And also don't forget gaskets and fluids. You can get a nice SLP Head cam bolt and gasket set for around $250 off of the WS6store that includes nearly everything you need.
Old Feb 5, 2009 | 02:38 PM
The Cook's Avatar
thanks. i found the ls7 clutch thread... ive been doing some research on them and some people have had some problems with the ls7 clutchs... i cant find a problem thread atm but it was something about it sticking or not releasing or something? are the ls7 cutches a problem sometimes?
Old Feb 5, 2009 | 03:42 PM
That's not a problem with the clutch thats a problem with the hydraulics. Most due to them improperly bleeding the lines are the swap. I would jump on that clutch deal if I were you.
Old Feb 5, 2009 | 04:02 PM
Im using an LS7 and havnt had 1 problem out of it.
Old Feb 5, 2009 | 07:20 PM
nmcqueen469's Avatar
Your stock injectors should be fine. The only way to really tell is to have your tuner look at the duty cycle and go from there.
