pushrod length
Old Feb 5, 2009 | 08:58 PM
1fastmofo's Avatar
Default pushrod length
I already searched and did not find anything does anyone know what size pushrod i need for my setup stock bottom end and bore 98 ls1 w tsp 2.5 5.3's w a torquer v2 specs are 233 239 598 603. also anyone know what injectors i need. other specs are fast 92/92 custom built lt's yank 3400 4:10 gear
Old Feb 5, 2009 | 09:03 PM
firefighter813x's Avatar
Have the heads been milled??
Old Feb 5, 2009 | 09:19 PM
1fastmofo's Avatar
no they have not...not sure that I have the ptv clearance for it? and if i do i think it was said to be very minimal that they would be able to be milled
Old Feb 5, 2009 | 09:55 PM
jsteele90's Avatar
i would get a pushrod length checker
Old Feb 5, 2009 | 10:01 PM
LQ9CHEVELLE's Avatar
Stock pushrod length is 7.400" and 5/16" diameter. If heads havent been milled to increase compression or decked excessively, stock length should be fine
Old Feb 16, 2009 | 09:02 PM
1fastmofo's Avatar
42lb injectors too much?
Old Feb 17, 2009 | 09:49 AM
CarsandWomen's Avatar
stock pushrods are 7.4 inches????? I just bought crane rockers pushrods guide plates and studs from a swap meet and the rods are 7.25 inches. wonder what thats all about. any ideas?
Old Feb 17, 2009 | 10:24 AM
99blancoSS's Avatar
You should measure with a solid in place of the same dimension.
Old Feb 17, 2009 | 10:13 PM
1fastmofo's Avatar
would 42 lb injectors be too much?
Old Feb 18, 2009 | 07:04 AM
vsocks1's Avatar
Can you just buy a solid lifter somewhere?
Old Feb 18, 2009 | 09:14 AM
99blancoSS's Avatar
All depends on what your using for lifters. You mght need to make a solid out of the hydraulic your using. They need to be the same height to get a proper measurement.
Old Feb 18, 2009 | 09:32 AM
vsocks1's Avatar
I am using Morel lifters - just got them finally! Don't have the stock LS6 lifters out yet, but I have heard they are a different length?
Old Feb 18, 2009 | 10:00 AM
99blancoSS's Avatar
The solid is the same length on the Morel. I am having a kit put together with a Comp cams pushrod length checker. It will have the solid lifter in it so all you do is use it and the checker, then measure the checker and voila (no guessing).
Old Feb 18, 2009 | 12:56 PM
vsocks1's Avatar
PM me how to order that!
Old Feb 18, 2009 | 02:06 PM
99blancoSS's Avatar
will do!
