Compression Ratio Driving Me Crazy!!
So i've been reading a lot this morning about CR. Im trying to figure out what mine is going to be. Can someone explain to me how to get it.
4.030 Bore
6.125 Rod
-3.2 Piston
64cc Chamber
3.622 Stroke
Not sure on gasket bore or compression thickness(GM MLS).
Also confused about deck height.
It'd be pretty sweet if someone could explain it to.
Thanks.
Also need to find out the head gasket thickness for us as well as how far the pistons are down in the hole.
But looking at your sig, and IF this motor is said 6.0 and your using 64cc heads on it, Id say 11:1 is in the ballpark.
My calcs were right on with smask using the original #s.
