Wierd Oil Pressure at WOT...
Old Jun 2, 2009 | 01:36 PM
Sk8runeg's Avatar
Default Wierd Oil Pressure at WOT...
My Oil pressure is about 25 or so at idle in drive.
When I start moving it will go up to like 40 pretty quick, but lately ive notices something wierd...
If I give it more gas from cruising the oild pressure will go up but then once it gets to like 3k rpms it will drop down to like 25 then jump back up at higher rpms...
Could this be a bad oil pressure sending unit or possibly something worse?
Thanks
-Scott
Old Jun 2, 2009 | 06:55 PM
01ssreda4's Avatar
mine did something similar and it turned out to be a partially clogged oil filter...
Old Jun 2, 2009 | 07:00 PM
King Nothing's Avatar
mine does the same thing . . . i'll be changing out the cam here soon enough and with that i'll have a ported oil pump
Old Jun 3, 2009 | 08:09 AM
Sk8runeg's Avatar
Ya it seems like its the oil pump to me.
When at idle the oil pressure gradually is getting lower day by day when the engine is hot, and when you are on it the oil pressure drops to like 10psi...
seems like a stripped gear in the pump.
Old Jun 3, 2009 | 08:36 AM
ericburt's Avatar
how many miles on the car?
Old Jun 3, 2009 | 12:06 PM
i know mine has 152K on that pump lol
Old Jun 3, 2009 | 03:15 PM
dre2013's Avatar
i would verify with a mechanical gauge...if it is really @ 10psi then i definetly wouldnt drive it until you fig out exactly what the prob is
Old Jun 3, 2009 | 08:46 PM
thank God mine isn't at 10psi or i'd really be worried when it's at it's lowest it's at 22-24
Old Jun 3, 2009 | 09:56 PM
SOMbitch's Avatar
A drop on acceleration can mean bearings as clearances open up, then as rpm increases so does OP as the pump picks up speed. Any metal on your drain plug or filter at oil changes???
