Am I Ready For WOT?
Old Nov 15, 2009 | 02:24 PM
C5natie's Avatar
Default Am I Ready For WOT?
These last few days Ive been breaking in my new motor. Its a LS6 with a stock crank and forged rods and pistons. It also has a FAST 92mm and TFS 215 heads 59cc for 12:1cr (with a little help from taller pistons). The cam is a 236/243 112lsa 4degrees advanced and comes alive north of 4000rpms. This thing was put together really nice and tight since I need it to last. I just put 600mi on it and have changed the oil twice, to be safe, and have somewhat babied it. Ive taken it up to 4000 and then 5000rpm on nice steady strong acceleration to make sure the piston rings seal well, just not wot. She sounds great, no blowby or oil consumption and I can tell its gonna be fast. This is my first built motor I break in from new and Im wondering if it should be safe to give her a wot to see what she has. My tech also told me once the motor is broken in he'll add around 3-4degrees more of timing for a little more power. Cars at 18 degrees of timing and seems to like it with no detonation. So, what do you guys say? Time to punch it?
Old Nov 15, 2009 | 09:34 PM
Mike454SS's Avatar
Put the pedal on the floor.
Old Nov 15, 2009 | 09:41 PM
1999FirehawkLS1's Avatar
O ya floor it
Old Nov 15, 2009 | 10:43 PM
LS6427's Avatar
You kiddin, that thing was broken in before it got off the dyno....I assume you had a dyno tune done. Just takes a couple dyno pulls to break it in.
You're way over due to go WOT...... DO IT!!!!!
Old Nov 15, 2009 | 10:47 PM
jcobra99's Avatar
Originally Posted by ls6427
you kiddin, that thing was broken in before it got off the dyno....i assume you had a dyno tune done. Just takes a couple dyno pulls to break it in.
You're way over due to go wot...... Do it!!!!!
Agreed.
Old Nov 15, 2009 | 10:49 PM
bombebomb's Avatar
I would of went WOT the second I pulled it out of the tuning bay. So yes, do it.
Old Nov 15, 2009 | 11:33 PM
eseibel67's Avatar
OP: Your powers of delayed gratification are impressive.
I would have mashed it by now.
Old Nov 16, 2009 | 12:04 AM
C5natie's Avatar
Well I did it. Went WOT and boy was it fun. Broke the tires the loose like if I was on ice. Shifts at 6900rpm sound great too. Just need to adjust the limiter on 2nd and we're good to go. Thnx guys. It was like busting a nut after a month of no sex. Lol.
Old Nov 16, 2009 | 12:26 AM
youguessit's Avatar
omg, i cant wait to get my motor done... i dont know how you waited a month, i predict i would last a week tops.
