torquer v.2 help
Old Mar 5, 2010 | 07:59 PM
synisterC5's Avatar
Default torquer v.2 help
does anybody know what #'s should be scribed into a torquer v.2 cam?
i just bought a used one from a member on here and the only etching on it is "233/233".
i measured it with some calipers and the lift is correct around .595-.600. i have no way of measuring the other specs of the cam though and im wondering if anyone else bought one with the same numbers on it?
any input would be greatly appreciated, my budget is running low and im praying to god that this is the right cam!!
Old Mar 5, 2010 | 08:02 PM
6.0 silverado's Avatar
isn't the TV2 a 232/234?
Old Mar 5, 2010 | 08:05 PM
synisterC5's Avatar
thats what im saying! its possible that they are based off a comp core at 233/233. i know private lable comp woud not put a comp label on it but this isnt making much sense to me.
Old Mar 5, 2010 | 09:20 PM
Austinma62's Avatar
Im not sure about this but wasn't the 233/233 the original torquer v1 cam?
Old Mar 5, 2010 | 09:34 PM
synisterC5's Avatar
i think your right, i dont think the v1 had nearly as much lift and from my calcultions i have between .585 and .598 on the intake and slightly more exhaust. im not sure what i have, the duration is close enough and the lift is fine but i have no idea of lobe sep, or lobe type?
Old Mar 6, 2010 | 01:34 AM
Maroslut2001's Avatar
My V.2 has the lsa scribed in the end of the cam and the specs are
232/234 .595 .598 i have mine on a 112 lsa
Old Mar 6, 2010 | 01:55 AM
$750 L98's Avatar
TSP Torquer V2 are essentially a Comp Cam XER281HR spec'd a bit differently, should definitely be a 232/234 .595/.598 cam though.
I have the same cam but in a 113+3 LSA.
I got this from another thread: TSP Torquer V1 (233/233 .589" 112*)
Old Mar 6, 2010 | 08:47 PM
desertLS1's Avatar
Starting to look like you got boned
Old Mar 6, 2010 | 09:08 PM
willystyle438's Avatar
Mine is the same as above. Just bought it from TSP about 4 months ago.
It's a NICE Daily Driver. Then again i only drive my car about once a week.
(Play Toy)
Old Mar 7, 2010 | 11:03 AM
synisterC5's Avatar
yeah, i think i got taken! i just need to find out what it actually is now. it still has the lift i need and close enough duration so maybe i didnt get screwed that bad!
Old Mar 10, 2010 | 12:51 PM
Project382's Avatar
For the price that was paid and the condition of the cam being off a few degrees isnt that bad. I'm more concerned about the lobe sep. That member still hasnt got back with me regarding a cam card or anything.
Old Mar 10, 2010 | 03:12 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
That is likely the TorquerV1....if you got a deal, I'd just go with it. It's still a nice camshaft and has similar lobe profiles to the V2.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
