Crazy issue!! Vehicle wont rev past 4500 but will in gear?
With clutch pressed in or in neutral vehicle will not rev past 4500 if you slam the throttle it sticks there and doesnt fluctuate much. Even if I roll into the throttle slowly when reaching 4500 it doesnt move.
So then I put it in gear whether 2nd or 3rd and start driving vehicle passes 4500 everytime with no issue. Only happens when out of gear..
At first I was thinking springs, or pushrod issue, or abuse management variables in tune. Not sure though vehicle drives great in and out of boost, and no drivetrain noise. There is one other small issue of when I downshift a higher rpm's and get back on the throttle quick car falls flat on face. I think these might be linked as it is the same feeling of not being able to pass 4500 and hitting a brick wall while accelerating. But when I duplicated the issue I was unable to catch what rpm it occurs. I believe these might be linked as they feel the same just seems like a bigger issue under max accel.
Any help or incite would be appreciated.
I'm pretty sure that nearly every LSx enthusiast has free revved their car to over 4500 at some point, especially after exhaust mods or when a new cam is installed.
My stock M6 doesn't have any provision to limit the rpms with the clutch pushed in or in neutral. Not sure if that is a feature that can be turned on, as I know many late model automatic vehicles have something similar.
LSX Mechanic
You can set the rev limit in park, neutral, gear, etc where ever you want via tuning software.
I once fucked with a buddy after I tuned his car, and set his rev limiter to 2500 while in gear. Then made him buy me a steak at Longhorns before I would remove it.
I LOL'd at this point.
I wonder if my tuner had something set in the neutral setting cause it is at 4500 everytime. I'm going to give him a shout tommorrow. About time to up the boost and retune anyway. And when it happens when shifting thru gears while accelerating hard it is normally after a fast shift. Wonder if its sensing neutral and locking me out. Only happens while accel once in a while. But everytime in neutral.
Engine is new.
