Got my 228r cam kit from tsp!!!!!!
Old 04-29-2010, 07:36 PM
98z28jorge's Avatar
Default Got my 228r cam kit from tsp!!!!!!
hey guys just got my cam package from tsp i went with the 228r 112lsa its an a4 dd i bought the dual spring package,melling oil pump,timing chain,and the basic gasket kit. but im concerned because i see that i didnt get any locks i was wondering if i could use my stock ones also i was told that the valve stem seals were different int and exh. but i got 16 of the same brownish looking seals is this ok or do i need to contact them and get different ones
by the way i crashed my 98 z28 and the motor is going in a 98 v6 fire bird im in the process of the cam swap while the motor is out side just wondering how will the car run with this cam and a 3200stall from circle d on stock 2.73s as a dd and track toy MODS TO THE CAR WILL BE THE CAM,LTS,TURE DUALS AND SLP LID THATS ALL FOR NOW
thanks in advance guys!!!!
Old 04-30-2010, 10:39 AM
98z28jorge's Avatar
come on guys no body has any info to help another f body rider out
Old 04-30-2010, 10:42 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Stock locks are utilized with the PRC dual spring kits. The seals that come with our kits (as well as the competitors') are the same for intake and exhaust.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-30-2010, 10:53 AM
98z28jorge's Avatar
oh ok thanks just needed to know for sure hopefully the cam will go in in about 2 weeks. what kind of numbers do you think i would put down or what it would run with Lts duals and lid on street tires i ran 9.0 in the 1/8th how much would i gain with the 3200 stall and cam install more or less!!!!
Old 04-30-2010, 11:03 AM
It's not unusual to see about 35-40rwhp gains with that cam even through the relatively drivetrain.
__________________
Old 04-30-2010, 11:32 AM
DUSTYWS6's Avatar
I put the same cam in my A4 and it's a pretty nice cam, pretty tame even on a 112 LSA since there isn't much overlap. Just some words of advice, until you get a tune, adjust the set screw for your throttle body blade abuot 3/4" of a turn folling the Throttle Position Sensor relearn process. This will help your idle and get you by until you get the tune. Also, watch how low you set your idle. I believe due to my low idle I was getting some valve opening overlap where I was getting fresh air in the cylinder which was getting out of the exhaust valve before it closed and subsequently I was running really rich at idle because of the "detected" lean condition. I bumped my idle up to 300 PRMs above stock idle and the problem cleared up.
Old 04-30-2010, 12:28 PM
98z28jorge's Avatar
ok thats great info thanks sence this is my frist cam install and cam car period so how did the cam affect the wot fun was it very noticeable or was it just a little extra boost iv never been in a cammed car so i dont really know how much of a difference it will make
Old 04-30-2010, 06:31 PM
Justus67's Avatar
You'd better run a trans cooler, those 2.73's can burn up that tranny with a stall.
Old 04-30-2010, 07:45 PM
98z28jorge's Avatar
dont worry i will the tranny cooler and shift kit too so does any one have a clue of how much better my 1/8th mile time would get
Old 05-01-2010, 12:45 AM
LSx99SS's Avatar
with my mods(see the sig) i run farely consistent 8.0xx's
Old 05-01-2010, 01:02 PM
danger ds's Avatar
My car with your set up on a 1.85 60ft hit a 12.54 at 113. I put down at that time 376rwhp 350Tq
Old 05-01-2010, 01:09 PM
twitchtwice's Avatar
my car put down the same power as ds's. with stock 799 heads. havent taken it to the track though.
Old 05-01-2010, 02:52 PM
danger ds's Avatar
do you think that tq is weak
Old 05-01-2010, 03:26 PM
i had 8 more torque then you. at first i was a little suprised at how low it dynoed but from the way it drives it feels like more of a gain then the numbers show. ill just have to take it to the track, thats the real way to test the car
i think the tuner didnt lock the converter when he did this tune so it reads a lot lower. he also didnt have my cutout open so i dont really take my numbers seriously.
Old 05-01-2010, 03:28 PM
Detoxx03's Avatar
What tires are you running? If that's on drag radials I'd expect a lower time
Old 05-01-2010, 03:53 PM
massconfusion's Avatar
i have the 228r cam with pat ls6 59cc heads, weiand intake with a fast 90mm, Lts, lid and 2.5 inch exhaust and a m6. My best time was 13.4 at 107 mph with a 2.2 60 ft time and .8 reaction time. this was also my very first pass so you can tell i should have seen mid 12's just based off of my trap speed and shitty reaction. I have .3 rts now but that with a bad clutch. Ethier way with your stall you will easily see 12's. I now have an 8.8 with 4.10s and a stage four monster so i am hoping to see low 12's maybe high 11's. Soon comes the spray. surge is very minimal as well very good cam i tuned it my self
Old 05-01-2010, 04:19 PM
danger ds's Avatar
That run was on street tires , stock gearing and 2500 stall.
Old 05-01-2010, 04:41 PM
jsteele90's Avatar
that should be a 11second setup with a good stall and some sticky tires
Old 05-01-2010, 04:45 PM
Justus67's Avatar
If you change to 3.42's or 3.73's the car will be a completely different beast.
Old 05-01-2010, 06:48 PM
98z28jorge's Avatar
Hey thanks guys the reason im consernd with my time is because my friend has a foxbody with a little head and cam package and he is runing a best of 7.7s in the 1/8th on mickey drs and he swears i cant even get close to him with a cam only set up he thinks i wont even be in the low 8s thats why im interested in finding out if i would even be able to give him a good race
oh and yes im going to up my 2.73 to 3.42s or maybe 3.73s
Quick Reply: Got my 228r cam kit from tsp!!!!!!
