New lifters with new cam? YAY OR NAY
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
i just got a 98 ss camaro, going to be doing a cam install in a month or 2. the guy i got it from said it was rebuilt like 30,000 miles ago. it has very good oil pressure. car has 149,000 miles on it. im pretty sure the lifters would have been replaced but the guy didnt know. and im just trying to get away with throwin the stick in and rockin it out down the road along with a ported ls6 oil pump and a ls2 timing chain. i didnt want to take the heads off just to change the lifters, i would do it if i was already changing heads but im not rite now at this moment its a slim budget build. but im just wondering if i should or need to change lifters with a new cam goin in even tho its been rebuilt and new lifters most likely dropped in. thanks sor
ry my story is 3 paragraphs long. and the motor will be in the car, so the heads would be a bitch and a half to get out ne ways. thanks
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
At that mileage I would definitely recommend lifters as well as pushrods. Why do it half-*** only to have it break down in a few thousand miles? Congrats on the purchase! Any paperwork on the rebuild?...
I personally would. IF the lifters were not swapped out you don't want to put the strain of the higher pressure springs on stock 150,000 mile lifters. it could very well not hurt a thing... but I'm one of those that is going to make sure I don't have to worry about comming back later to change something b/c I didnt replace it to begin with.
https://ls1tech.com/forums/parts-cla...er-lifter.html
Christian
For the price they are advertised below it's a win/win situation...
https://ls1tech.com/forums/parts-classifieds/1278079-fs-morel-billet-hydraulic-roller-lifter.html
Christian
Might be or might not be overkill...in any case the Morel's are way better quality than the LS7...able to run moe RPM saving your drive-train, have a lot longer life vs. the LS7 for the same usage...and are rebuildable!!!
Christian
Christian
With having 149,000 on the motor & not knowing if they were replaced when rebuilt thats really rolling the dice but you might be alright just putting a cam in it. When I did my cam I didnt replace the lifters, but since I am gonna be replacing the heads soon its getting new lifters & trays too. Oh & make sure you upgrade to some good hardened pushrods with the new cam.
If the OP is on a 'slim budget build' then the Morel's should be out of the question even at $350 used. However, I haven't seen any mention of checking/replacing the valvesprings depending upon the type of cam being purchased. If the base circle on the cam changes, it'll affect your preload and you should at least check for correct pushrod length. If you're not pulling the heads, then insure you get the metal dowel rods to keep the lifters up while swapping the cam.
If you can afford the parts, labor, and downtime, then do something like:
cam
PAC 1518 beehives ($188, SDPC)
LS2 chain ($32, GMPP dealer)
LS7 lifters ($110, GMPP dealer)
LS2 lifter guides (5-pack, $17.50, GMPP dealer)
LS1 head gaskets ($38 x2, GMPP dealer)
LS1 head bolts ($20 per head x2, GMPP dealer)
pushrod length checker
Pushrods (11/32 or 3/8 x .080+ wall, ~$10 x 16)
thanks for all the input guys, i will be doin prolly a custom grind comp cam close to tsp's 233/239 cam. and will be doing valvesprings and pushrods along with that. and it is on a budget i think i just mite put the cam in and when i have more money for the 243s i will do them along with the ls7 or caddy lifters. i just cant see taking the heads off enless i got some better ones to put on. i have no paper work that the engine was rebuilt but it has badass oil pressure and has no lifter noise even when cold, like most high mileage low oil press. ls1s do. i can just hope that they are new.
You can buy dowel rod at any hardware store, it can be any material (aluminum, steel, wood) but wood is cheapest. You want 1 rod, 5/16 X 48 inches long then cut it in half. Slide these in the 2 oil galley holes behind the cam retainer plate & it holds up the lifters. Then pull the cam but first spin the cam a few times, that will push the lifters up in the trays.
I'm new at all of this, but I as I was learning about what to do as you swap a cam, I found out about the LS2 timing chain upgrade. But I guess I was mistakenly assuming that you also would change out the sprockets too, but really its recommended to just change the chain itself? That's good news for the pocket book!!
EDIT: By the way, what is the benefit of the LS7 lifters vs stock LS1 lifters?
Is anyone running the LS7 lifters with the heavy duty #8019 AFR springs? I am looking at only buying this stuff once and need to find a lifter that can handle the load. Also what about the comp cams "R" lifter?
