How do i go about cleaning my pistons?
Banging some gears
Well its like the title says.. How do i go about cleaning my pistons while they are still in cylinders? is there a certain scuff pad i can use? or type of chemical? Everyone tells me its a waste of time but i have nothing else better to do til i recive all my parts to put the engine back together.
any help is appreciated
Daniel
Daniel
This is a piece of cake. Bring a couple pistons pretty close to the top, and spray some brake parts cleaner on top of them. Enough to puddle on top of the piston and cover the carbon. Let it soak 5 minutes, then roll the crank till the piston is at the top and literally they will wipe clean with one wipe. Make sure to oil the cylinder walls down good after you are through, as the BPC will strip the oil coating off.
I took the time-consuming approach and scraped it off with a razor blade. Of course I went extremely slow and at a very narrow angle to avoid gouging the metal. Of course this worked well to get all the old headgasket material off of the block too - followed it up with some 1500 grit sandpaper for some areas that wouldn't seem to come clean.
![](http://i69.photobucket.com/albums/i64/ggsz28/005.jpg)
If you let BPC soak for about 5 minutes, the carbon literally falls off. I dont understand why anyone would scrape anything.
OP, you wont even use 1 can for this....Go easy on the trigger and just let it fill the cylinder up just above the piston head (wont take much)
Both methods work apparently - I tried chipping it off with my fingernail initially and when I realized it wasn't going to be easy I just didn't think BPC would work. In hindsight I would've tried a rag sprayed with BPC - just not crazy about letting it drip down the walls and into the pan.
