Pushrod length sanity check
It seems to be the loudest on the passenger side of the engine.
This is far from a radical combo and feel it should sound near stock.
When using an adjustable pushrod, my measured (via caliper) pushrod length at zero lash was 7.230. An extra .050 for lifter preload would put me at 7.280. I ordered 7.300 and threw it all together. On startup it sounded pretty nasty, but started quieting down as the lifters pumped up. I have a steady and consistent knock that I feel is still coming from the valve train.
Once I started researching the issue, I've found people mentioning gauge length vs total length of a pushrod. Is the difference in gauge vs total length something that could have lead me to order the wrong pushrods?
Given the above info, what pushrod length would you suggest?
The difference between these two definitions doesn't change the actual length, they are measurements of the same pushrod taken at two different locations. If your valve train is noisy, I would ask how you measured the first time to determine if you measured correctly.
(In my case I measured using Comp Cams adjustable pushrod and determined a specific length to order. The problem was I ordered from Manton who is a "overall" length supplier. I came up short. Stated another way my Comp Cam adjustable pushrod, which is label 6.80 has an overall length of 6.817.)
I will be opening it back up to re-measure tomorrow. I just wanted to make sure I was correct in my math before going through the trouble again. It sounds as if the gauge length should have come out in my favor in this scenario, adding to my preload.
For cyl #1, the lifters are on the cam's base circle when both cam/crank dots are at 12 o'clock.
The EO/IC method is also accurate practice for finding the cam's base circle.
I'm installing milled heads (TSP 5.3's down to 59cc) and the LS7 lifters and I'm anticipating needing 7.3" for my PR's once I throw it together.
I ended up with much different numbers this time. I broke out the adjustable pushrod set at 7.367 (total length) and ended up with 1 5/8 turns exhaust, just a hare shy of 2 turns intake. I'd feel comfortable calling it 1 7/8.
Measuring with my 7.3's and stock 7.4's I'm noticing a pretty consistent trend that the intake looks like it may need .025 shorter than the exhaust. Should I simply run 7.350's all the way around and run with the additional preload on the intake? Or should I get 7.350's for the exhaust and 7.0325's for the intake?
I did mention these were ported 853's, but neglected to mention they do also have aftermarket valves as well. They're Lloyd Elliot Stage 2 heads. Is it common to have to staggered push rod lengths to make up for valve differences? I'm guessing the intake valve stem is longer, or the valve is recessed in the head a little. The cam is .551 lift on both intake and exhaust. I'm not certain where else the difference could be coming from.
With 7.350 all the way around I'll have .076 preload on the exhaust, .088 on the intake. With 7.320 on the intake side, I'd be looking at .061 preload. At this point I'd like to err on the high side of preload if possible.
On a related note, I realize .050 is commonly referenced as the minimum preload, but what would optimal and maximum operational preload be with LS7 lifters? I keep seeing a max preload numbers between .100 to .150 thrown about, but haven't found anything that's a little more definite. A thread on hardcorels1 made reference to almost .200 before bottoming out and referenced info gleaned from Predator-Z stating that stock preload was in the .080 to .100 area. I take all that info with a grain of salt, but want to find as much info as I can to make an informed decision.
EDIT: After reading quite a few more threads, I'm going to run with the 7.350 all the way around. I've found info from multiple sources (vendors) stating the LS7 lifter can be noisy at or below .060 preload.
Again, it's the passenger side that is much louder than the drivers. I've swapped the rockers between bank 1 and 2 to insure it wasn't anything there. Anyone have any other insight as to what's going on here? The intake's ended up being a little tighter than I had expected, and are just at 2 turns preload.
w/ 7.300 push rods
http://www.youtube.com/watch?v=vI0emQAcegk
w/ 7.350 push rods
http://www.youtube.com/watch?v=ziH1Y1KUUkw
I have also tried two different sets of header gaskets. I had a set of paper gaskets when the engine was first installed; I've since moved to a set of good stainless steel gaskets with the same noise.
There was a post within the past few days where someone couldn't correct their noise (it was a shop) and finally went to a different cam with a different lobe, problem went away. You may want to contact them. Here is a link: Link
