Bent Some Valves, Are These Pistons Okay to Use?
Well I accidentally shifted from the top of 3rd into 2nd. I pushed the clutch in almost instantaneously but it was still enough to bend 15 pushrods and several valves. Every piston has at least one small nick on it but here are a few pictures of the worst off ones. I'm pretty sure I can still run them, since some people have fly-cutted a lot deeper than these nicks but wanted some second opinions...
Could probably get away with using some red scotch pads they sell at the car parts store (they're priced kinda high at autozone though). Or you could use some fine grit sand paper. I'd start with 400 grit and move up to smooth it out. Either way make sure you clean out the cylinder well when you're done.
I agree with the other guys. I have put back several motors with simelar damage. Scotch pad just to take off the rough edges. If you do have any sharp edges the motor will burn down. The sharp edge will heat up and possibly glow and give you detonation or preignition.
1 Post
man thats horrible, it got me thinking how lucky i have been a few times. for some reason i had an issue where i was going back into 1st gear on the 2nd to 3rd shift, my tires started chirping and my low trac light turned on. the car is running fine tho
