El toro cam
Old Jan 22, 2011 | 10:19 AM
1sloz71's Avatar
Question El toro cam
Hey guys hows it going, just wondering if any of you guys knowwho make "el toro cam" , ?
Thanks a million!
Old Jan 22, 2011 | 10:29 AM
slt200mph's Avatar
Thanks a million!
Why don't you call Scoggin-Dickey and ask them it is the long block that they market ... my educated wild azz guess would be Comp ..
Old Jan 22, 2011 | 01:07 PM
SOMbitch's Avatar
It is a custom specced by Predator-z. 230/230 .612/.594 111+4 Most just advance it 2* though. It is ground on comp XFI intake/X-ER exhaust lobes.
Old Jan 22, 2011 | 01:09 PM
99Bluz28's Avatar
3016 (intake XFI lobe) 3725 (exhaust X-ER lobe)
230/230 .612/.592 LSA 111+2...
Old Jan 22, 2011 | 02:22 PM
PREDATOR-Z's Avatar
That would be my grind,
The most popular variations are:
230/230 .615/.592 111+2 LSA (on stock motor)
230/228 .615/.588 110-1 LSA (does better in Vettes)
Old Jan 22, 2011 | 02:36 PM
Titanws6's Avatar
I'm making 410hp/390tq with this cam and supporting mods, the TQ curve is very smooth and has a nice "table top" quality to it. Has a nice lope to it too.
Old Jan 22, 2011 | 08:11 PM
TXZ28LS1's Avatar
Pred, that 230/228 is the same cam that RMTT is running correct? That cam make big power for being a reverse split. Made great power stock heads and insane power with heads.
Old Jan 22, 2011 | 11:19 PM
Blu99T/A's Avatar
I have it as a 230/232 .613/.598 and love it. Great torque all around.
Old Jan 23, 2011 | 01:21 AM
PREDATOR-Z's Avatar
Yeah, witha good set of 59cc Cartek 243s 4X, he made 465rwhp and 427rwtq.
400rwtq @ 3500rpm
Old Mar 17, 2022 | 03:08 AM
Torqueonboost's Avatar
Thanks a million!
Who is is still using this cam in 2022??
Was the best cam I ever used to date.
It is my second time round doing a cam.swap on a new beast, same specs ls1 3:9 diff gears 3800 stall 4l60e car weighs 1780kg or I think that's 4000 pounds.
Anyone found a better cam than this after using it?
Old Mar 17, 2022 | 03:10 AM
Default Predaror Z
Is Predator Z still around?
lobed the 230 230 you created. Just seeing g if you found an even better cam. Lived the way this thing would come on instantly and roast tyres
Old Mar 17, 2022 | 09:39 AM
Neither guy you are addressing has been around here for many years. The thread is 11 years old.
Which cam spec are you referring to?
Don't use names when referring to a cam. Always use duration, lift, and LSA (lobe separation angle). That way anyone can know of which you are referring to.
Old Mar 17, 2022 | 11:02 AM
low2001gmc's Avatar
MASS seller approved
I would consider redoing the EL TORO CAM using more modern tech TSP Lobes and do 230-230, 629-615 LIFT, on same 111+2 LSA.
Or consider Kentucky Speed's All ***** Cam at 231-238, 629-615, 111+4...
