any idea where this oil leak is from? pic
ok, the front of the car is jacked up and has not been running for about a month, the oil still drips. i was thinking oil pan. but theres drips on the starter (pic) and thats higher than the oil pan.
i was thinking rear main, but it hasnt been running?> any ideas?
i was going to do the oil pan gasket, but if thats not it, i dont want to change it for nothing.
any input...
any input...
![](http://i389.photobucket.com/albums/oo333/vbstng/IMG_3857.jpg)
I would wipe all that down to get it clean and dry. Then let it sit for a few days and then go have another look. Who knows by looking at all those wet spots. Looks like oil has been blowing around for awhile during driving so its hard to pinpoint with that going on. You could have multiple leaks or just one. Wipe it down and find out!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
ok, i might do the oil pan now, im doing long tubes and motor mouts, oil pan shouldnt be that hard with all them parts already out.
i did degrease the whole underneath, and let it sit, and this is what happened, it drips without the car running...
the valve covers are already replaced.. i was thinking rear main also. but not running will it leak?
oil pressure sending unitis behind the intake right?? intake has to come off dont it??
whats the sensor right above the starter? i cant really see what it is...
the pcv setup is still stock. no catch can or anything..
I am able to replace my oil pressure sending unit without removing the intake in about 5 minutes with the special socket from the parts store. ( yes behind the intake more towards the driver side)
oil pressure sending unitis behind the intake right?? YES intake has to come off dont it?? depends on if u have the socket like sad above
whats the sensor right above the starter? low oil sensor i cant really see what it is...
