What Quench should i shoot for?
Old Feb 23, 2011 | 05:17 PM
Fastdriver1992's Avatar
Default What Quench should i shoot for?
i just rebuilt the bottom end on my ls6 stock crank compstar rods and weisico pistons. with a .050 gasket im getting around a .060 quench. is this way to much? how much should i be running. its a race car track only on pump gas 93 and around 10.8:1 compression
What quench should i go for to give me the most power
Old Feb 23, 2011 | 05:26 PM
chrs1313's Avatar
stock is around .045...ideal is closer to .035-.040
Old Feb 23, 2011 | 05:41 PM
Mike454SS's Avatar
I shot for .040 on my build...you're going to have to go to a thinner head gasket to bring it up though, not sure if you're against the compression ratio increase. Have your heads been ported? Some port/chamber work will bring the CR back down afterwords.
Old Feb 23, 2011 | 05:50 PM
PREDATOR-Z's Avatar
Old Feb 23, 2011 | 06:44 PM
BriancWS6's Avatar
I ran .032-.033 with my stock short block with excellent results, just built a 347 for my buddy and set his at .033, and my own build I will be doing later this year I will have at .035.
.040 would be as loose as I would want it. BTW, you can bump your compression on up in the 11s a good ways even on 93. I would definitely go with more compression since you said it is a track only car.
Old Feb 24, 2011 | 12:21 AM
how much hp am i gonna loose with a .060 quench as to .040? i drag race the car will i see a large difference in 1/4 time/mph? is it worth buying the thinner gasket?
Old Feb 24, 2011 | 04:56 PM
bww3588's Avatar
optimum quench is between .030 and .040
Old Feb 24, 2011 | 05:00 PM
intenseblue's Avatar
HP/$ ratio is on par with what an underdrive pulley would be
