5/16 locks on an 8mm valve stem?????
Old 03-15-2011, 01:22 PM
blown99bergerssclone's Avatar
Default 5/16 locks on an 8mm valve stem?????
Has anyone done this? The makers of xceldyne retainers and locks are telling me it's ok and that with the psi spring I bought I have to run their retainer with this spring and that they only make 1 lock for that retainer due to it being a 7* top lock. Said that the difference between the 5/16 and the 8mm are close enough to be safe. Any input from y'all would be great including sponsors. Are any dealers for these brands?
Old 03-15-2011, 04:54 PM
dodson55's Avatar
I know there is only a couple thousands difference in the two I think it would be ok but I would do some more checking before I did it
Old 03-15-2011, 06:21 PM
Mr MasterCraft's Avatar
All I can say is, I just found out yesterday that the battery cable bolts are 5/16". I've been using 8mm for years and years on the 7 I've had, and the two GM trucks I've had
Old 03-17-2011, 11:35 AM
SSCamaro99_3's Avatar
I would not equate using an 8mm socket on a 5/16 bolt with doing so on valve retainers.
Old 03-17-2011, 12:12 PM
A_VAS's Avatar
I would trust Xceldyne's word over anything I read or heard on the internet
Old 03-17-2011, 07:34 PM
S10xGN's Avatar
FYI, 5/16" = 0.3125 & 8mm = 0.3150, that's a difference of 0.025". I'd be looking at how the locks fit grooves in the valve stem...
Old 03-18-2011, 03:11 PM
ss1
ss1's Avatar
You may have been having a bad day, but the difference is .0025" (or two and a half thousandths), not .025" (or twenty five thousandths of an inch). I would believe what Xceldyne says as well.
Old 03-18-2011, 08:26 PM
S10xGN's Avatar
Yup, dropped a zero...thanks!
Old 03-18-2011, 10:46 PM
Thanks I am going to go with what they say. I
Just hoped someone's had ran into this.
Quick Reply: 5/16 locks on an 8mm valve stem?????
