Head bolt
Old Mar 18, 2011 | 08:25 PM
VandykeT/A's Avatar
Default Head bolt
Has anyone had a head bolt strip in the block and drilled it out and tapped it with a bigger bolt ? A friend of mine doing the work to my car had this happen and had to do this and i was wondering if anyone else has experienced this and if its a common thing ? Thanks
Old Mar 22, 2011 | 10:56 AM
VandykeT/A's Avatar
.... bump
Old Mar 22, 2011 | 11:58 AM
CrazyDrivinJoe's Avatar
I had one break when installing headers but I got it out honed the hole with a spare bolt by flatening 2 sides and going in and out clearing the hole. Got the idea of google header bolts fit perfectly after. If you are talking about the head bolts then thats a whole nother story
Old Mar 22, 2011 | 12:28 PM
splitfinger09's Avatar
I just swapped my heads with no issues of stripping. I would def say this is not a common thing.
Old Mar 22, 2011 | 02:13 PM
crainholio's Avatar
The bolts which attach the heads to the block need to apply the same force or the head will warp. It is unlikely you could accomplish this by mixing in a single bolt of different material and size.
Better to use a threaded insert (Timesert?)
Old Mar 22, 2011 | 03:57 PM
joecar's Avatar
Look thru this thread: https://ls1tech.com/forums/generatio...ipped-lsx.html
Old Mar 23, 2011 | 02:21 PM
speedtigger's Avatar
Old School Heavy
Heli- coil thread repair kit may be an option.
Old Mar 23, 2011 | 02:27 PM
VandykeT/A's Avatar
Hes all ready drilled it out and put the bigger bolt in.
Old Mar 23, 2011 | 08:11 PM
S10xGN's Avatar
Good luck with that...
