How much compression is lost from a .065" flycut?
Old Feb 24, 2004 | 08:55 PM
verbs's Avatar
Default How much compression is lost from a .065" flycut?
Like the title says....any ideas?
Old Feb 24, 2004 | 08:59 PM
Beast96Z's Avatar
My -2cc cuts are about .150" deep, so I'd say less than 1cc.
Old Feb 24, 2004 | 10:05 PM
triumphman's Avatar
i get 13 cc's 3.900 x.065 x 51.48 thats alot to flycut i would get the right rods.
Old Feb 24, 2004 | 11:02 PM
Beast96Z's Avatar
You got me a little confused. He is flycutting his stock pistons to accept a larger cam. There is no need for diffrent rods. No way will you loose 13 cc's with a .065' eye brow in the piston. Like I said before it will be 1 cc or less.
Old Feb 25, 2004 | 01:04 AM
verbs's Avatar
Yeah I'm w/ you
Old Feb 25, 2004 | 11:58 AM
DanZ28's Avatar
1 cc = .061"
So Beast96Z about hit it on the nose..
Dan
Old Feb 25, 2004 | 01:08 PM
triumphman's Avatar
flycutting means machining the whole piston top,what you really wanted was cc's for .065 valve reliefs.
Old Feb 25, 2004 | 04:34 PM
DanZ28's Avatar
Don't you flycut for valve reliefs?
Dan
Old Feb 25, 2004 | 05:24 PM
verbs's Avatar
So back to my question, how much compression do I lose by flycutting .065" or just a shade under 1cc
Old Feb 26, 2004 | 03:16 PM
verbs's Avatar
someone's gotta know this!
Old Feb 26, 2004 | 03:51 PM
Damian's Avatar
LSX Mechanic
I wouldn't worry about it. 1 cc isn't going to make any kinds of difference, maybe 3-4 HP at most, which will be made up by the cam anyway......Go build your **** and stop worrying about it
josh
Old Feb 26, 2004 | 04:17 PM
triumphman's Avatar
it takes 2cc to move 1 compression point. ie. 10.3 to 10.2 = -2cc's
Old Feb 26, 2004 | 10:12 PM
verbs's Avatar
josh
****'s being built!!! Should be assembled tomorrow (hopefully)...with some dyno #'s I hope. I ended up milling the heads a bit to make up for it .
Old Feb 27, 2004 | 12:31 AM
AZ Power & Sound's Avatar
josh
Hes a ricer... if he could make 1 rwhp by stripping the finish off his valvesprings he would do it
Sorry verbs but I had to
Old Feb 27, 2004 | 04:16 AM
Damian's Avatar
LSX Mechanic
While he's doing that i'll take care of that girlfriend he posted pics of
jk
Old Feb 27, 2004 | 11:16 AM
verbs's Avatar
jk
LOL.....I'd let ya if I thought you could handle it
