valve springs
Im just looking for reliability ie: valvetrain
Apart from that, consider that you're planning to put a 14+ year-old engine through 20 or more minutes of continuous abuse in basic hobby-type HPDE tracking. Bearing clearances are likely larger from wear, valvesprings are fatigued, etc. Not a recipe for success.
Can you elaborate on the oil system issues? high flow oil pump meaning flow and pressure?
I've always tracked bmw's as they seem to be ready to go with only some suspension mods, so its interesting to hear what its gonna take to make my camaro a reliable track beater.
btw. I have more fun in the camaro than my bmw. even the though I lap faster with the bmw.
If it was mine, I'd replace the valve springs (PAC 1218 beehives), oil pump (Katech ported), and timing chain (JWIS C5R chain from Katech). Run a high-zinc (good EP lubricant) oil like Red Line or Valvoline VR1 in higher viscosity, and keep the revs below 5000.
If your engine has provision to fit a chain dampener, do so.
You need a bigger volume & baffled sump & or run an Accusump.
Power steer cooler is a must.
When he says power steering cooler is a must, i agree with him. but if yours is equipped with one stock, that does not count cause it is a huge POS!!!! get a real one that mounts infront of the radiator.
A stock LS1 cam isn't making peak power above 5K anyway, no reason to spend time there. Upshift and put the engine back into its happy place.
Particularly if he's like me and drives the car to/from the HPDE track days. All the really fun road courses are outside the AAA free tow limit.
So you're saying that C6 R cars are changing at what?
My take would be 6k or close.
It all depends on the cam you have and at what rpm peak torque is. My peak torque is 6k so I change at 6k, If I was doing road racing with my old cam TSP 231/237 I would be changing at 6500rpm.
So is anything over 5k, 'ringing the snot' out of an LS motor?
The design of the oiling system on the LSx engines do suck though. For road racing, you may want to at least add an accusump.
