Need help with 3.905 bore mahle pistions
Is this a set of 3.905 pistion or 3.910 pistions? I had a 5.3 block bored to a 3.905.. These pistion seem very tight in the bore.
Are these pistion for 3.910 bore..
![](http://i136.photobucket.com/albums/q169/kevhill85/96%202dr%20Tahoe%20prostreet/1fe999c1.jpg)
Summit show they are for 3.905 bore.. Did summitracing sent me the wrong pistons
Mahle LS1314905F04 - Mahle PowerPak Piston and Ring Kits - Overview - SummitRacing.com
My question is I order 3.905 bore piston and is this normal spec for these piston?
That's why you get the pistons then you do the final bore size...not the other way around.
If you set the bore then try to stuff a piston in there you're going to have this very problem. But if you had gotten the pistons first and had the machine shop spec the bore for them then it would've been fine.
You are correct .I am doing this as well. That why the block has a roughy bore and his not been final bore untill the piston where here. My question was asking the forum is this label right or wrong. I want a 3.905 bore motor and not a 3.910. No matter what is said in a forum my machine shop will do hats right for the motor..
if you had it bored, not honed and are trying to fit 3.905 pistons in it, its obviously going to be tight. what size was the bore you are trying to test fit them in?
something is not adding up.
which is it? you had it bored to 3.905? or is it rough bored to 3.900 and still waiting on a final hone? did you already have it honed to 3.905 before ordering the pistons?
it seems that if you have these tools already then you could measure and know for sure if you have the right pistons or not. am I missing something?
I post a photo of spec of piston that I have bought . I asked is this a set 3.905 or 3.910 set of piston by the spec On the photo I posted .. . I do not know know how the links you posted help.. All I asked was for some else to translate the spec for me. I wanted to see if I was reading the spec right.
