Pistons above block deck?
Old 05-15-2012, 02:46 PM
jak2908's Avatar
Default Pistons above block deck?
Got a rebuilt motor with Mahler forged pistons in it and when the piston is at tdc it is above the block deck about 1/32 of an inch? Is this okay???? It's been run before but not by me
Old 05-15-2012, 02:51 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
1/32 = .03125".....that's too much.
Are you using a piston bridge tool to measure it at the center of the piston without it rocking?? Or are you measuring it near TDC on the side that is rocked upwards? Most of the time pistons will be setup from about .010" in the hole to .010" out of the hole (when measured correctly)!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-15-2012, 03:09 PM
DONAIMIAN's Avatar
Are you just eyeing it, or did you measure?
Old 05-15-2012, 05:27 PM
jak2908's Avatar
Eyeing it
Old 05-15-2012, 05:32 PM
You cannot eye this measurement. At TDC and a few degrees each side of TDC the piston will rock slightly and one side will look as if it's out of the hole substantially and the other will be in the hole.
__________________
Old 05-15-2012, 05:42 PM
jak2908's Avatar
I'm sure it's fine it's just I noticed it more on this motor than my older one
Old 05-15-2012, 05:47 PM
edwardzracing's Avatar
I'm sure it's fine? Wow, you got guts. Best of luck!
Old 05-15-2012, 06:19 PM
jak2908's Avatar
Well the motor has been run before so it must have worked???
Quick Reply: Pistons above block deck?
