Piston To Valve Trouble LS1 to LQ9
I'm at a loss on what's going with my build. I swapped all my parts from my
ls1 to my lq9. Same 59cc TFS heads, timing set, YT rockers and cam. I flycut .085 on intake and .100 on exhaust using Lindy cutters in same head. Cam is degreed same as old motor. Cam specs are a custom grind:
.243/.246 .624/.615 110lsa +2 advance. I'm checking it with checker springs and .040 head gaskets. When piston is top dead center, The intake valve can't move any more. I can't rotate the engine without it stopping. I just don't get it. I had slightly less flycuts in my ls1 than these.
