lm7 swap into lt1 car
Old 12-04-2012, 08:02 PM
98cobrakiller's Avatar
Default lm7 swap into lt1 car
my friend has a 94 z28 and we are thinking about swaping in a 5.3 lm7 what all would we need to swap it.
Old 12-04-2012, 08:03 PM
garygnu's Avatar
different K-member for a ls1 ,and a wiring harness and ECM for that engine.
Old 12-04-2012, 08:11 PM
will a ls1 harness and ecm work
Old 12-04-2012, 08:19 PM
is it a plug and play and whats al envolved
Old 12-05-2012, 06:58 AM
Snkebait95's Avatar
Check out my build thread. 5.3l into 95z
https://ls1tech.com/forums/conversio...to-95-z28.html
Old 12-05-2012, 05:07 PM
thanks man this helps alot.
Old 12-05-2012, 06:32 PM
93Z2871805's Avatar
Any LS is the same process. Hope this stuff helps.
https://ls1tech.com/forums/conversio...on-sticky.html
https://ls1tech.com/forums/lt1-lt4-m...going-lq9.html
https://ls1tech.com/forums/conversio...dark-side.html
https://ls1tech.com/forums/conversio...-6-0-swap.html
https://ls1tech.com/forums/automatic...questions.html
https://ls1tech.com/forums/conversio...rsion-how.html
Old 12-06-2012, 05:41 PM
thanks guys i appreciate the help
Old 12-08-2012, 06:13 AM
does anyone know if the reculator wheel is a 24x or 58x so it will comply with the ls1 ecu and harness
Old 12-08-2012, 07:03 AM
sreve's Avatar
LM7 is a 24 tooth
Old 12-08-2012, 06:01 PM
no matter the year? m lookingfor the 05 up with 243 heads at my local salvage yard for 500.
Old 12-09-2012, 08:47 AM
sreve's Avatar
almost
see pdf
File Type: pdf
Quick Reply: lm7 swap into lt1 car
