New cams from Tick Performance
Old Mar 3, 2015 | 08:53 PM
  #1061
1970camaroRS's Avatar
My custom spec'd Tick cam in sitting safe and sound inside the engine now. No lifters went clanking into the oil pan! Waiting on a few ancillary parts to arrive for me to finish up a LSXrT intake install, then it's go time.
Old Mar 3, 2015 | 08:57 PM
  #1062
Rise of the Phoenix's Avatar
Originally Posted by poltergeist 02
I fly cut my pistons .070" intake and exhaust and I figured it to be about 1-1.5cc.
Does the Lindy fly-cutting tool have some type of provision that lets you set the depth and when doing that, won't allow it to go deeper?
Old Mar 3, 2015 | 09:15 PM
  #1063
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Yes it does
Old Mar 3, 2015 | 09:27 PM
  #1064
Thanks, that's good to know. Probably be much easier to do just dropping the k-member and having all that room.
Old Mar 3, 2015 | 10:31 PM
  #1065
poltergeist 02's Avatar
I didn't do that but if I had to do it again I would. There is a locking collar that goes on the shaft of the Lindy fly cut tool. What I did was made a .070" U shaped shim that I could slide under the collar to set max depth of the cut.
Old Mar 4, 2015 | 12:43 AM
  #1066
DoggyB22's Avatar
Originally Posted by Martin@Tick
Your 4.30 rear gear selection is a good one IMO, but it may need 7000-7200 through the traps on the spray, possibly even higher depending on tire size. On motor I feel that gear is perfect for a 6800rpm-7000rpm crossing RPM.
For sure Thanks.. Sorry thought I posted it haha Id be on 28" M/T ET Street Radial Pros
Old Mar 4, 2015 | 03:20 PM
  #1067
Sales@Tick's Avatar
Thanks Martin. So how do you go about making sure that SCR and DCR are met? Am I wrong in saying that the amount you have to fly-cut plays a factor in SCR and DCR compression? I know the more you mill the heads, the deeper you have to fly-cut, correct?
IVC and SCR determines DCR, but DCR can be tricky and misleading.
I don't pay it(it being DCR) nearly as much attention as I used to, if any attention.
We drop the K-member on any head/cam install we do on a F-body. Makes it much easier to work on.
Old Mar 4, 2015 | 11:57 PM
  #1068
dr_whigham's Avatar
The Scammer Hammer
IVC and SCR determines DCR, but DCR can be tricky and misleading. I don't pay it(it being DCR) nearly as much attention as I used to, if any attention.
Bah!!! Finally!! Someone ELSE who gets it!!
Old Mar 7, 2015 | 12:45 PM
  #1069
Martin, do you think there would be any benefit switching intakes from my current 92mm setup to a 102 or even an MSD intake? I'm also considering having my car retuned in SD.
Old Mar 7, 2015 | 05:45 PM
  #1070
inssanity21's Avatar
I think you should do it so I know if I should.
Old Mar 7, 2015 | 06:22 PM
  #1071
Hahaha, if I do, I'm not telling you until after we get our cars lined up!
Old Mar 9, 2015 | 12:50 PM
  #1072
Sales@Tick's Avatar
Not really. I think the Fast 92 is a very overlooked item as it has always laid down great numbers for us.
Not really a fan of the 102.
Old Mar 9, 2015 | 05:59 PM
  #1073
69gto96z's Avatar
Got my SNS 3 on the dyno today. Made 403/390 before tuning for nitrous. Made 391/387 with 6 degrees pulled out. On a NX proton 150 shot, made 540/628 I am a very happy camper. Thanks Martin.
SNS 3 with .660 springs
stock 241 heads
36 lb injectors
ported MAF ends and TB/LS6 intake
no UD pulley
Old Mar 10, 2015 | 08:04 PM
  #1074
SoonerBrad88's Avatar
Pretty nice numbers for essentially a cam only car. I'm waiting for my new rearend to come in so I can get mine tuned and see what Martin's custom grind did for me. It's essentially a SNS 3 but has more lift.
Old Mar 11, 2015 | 04:09 AM
  #1075
DoggyB22's Avatar
Anyone got some average hp/tq numbers for a car with my mods (in sig) + a TP Polluter cam, Ported & polished 243 heads & 150 shot as well
Old Mar 11, 2015 | 06:23 AM
  #1076
Well, I guess I'll just stick with what I have. I'm in the middle of looking for a used rear for my car right now and I plan on taking it back to the tuner as well to have the shift points moved up to 7000. I'll keep you posted with future results!
Old Mar 11, 2015 | 07:44 AM
  #1077
69gto96z's Avatar
Thanks, i am very happy with it. Martin does great work. Here is the graph, this run it made 405, but the tuner backed the timing up 1 degree because it made power a little earlier with less peak. On the nitrous pull he let off at 6600 where the window switch cuts off. I plan to shift about 6800.
Old Mar 11, 2015 | 02:38 PM
  #1078
Sales@Tick's Avatar
stock 241 heads
36 lb injectors
no UD pulley
Nice numbers!
10's are right around the corner!
Looks good!
Old Mar 13, 2015 | 02:43 PM
  #1079
Could anyone lead me in the direction of some technical reading regarding detailed engine building that would help me better understand things like IVC, SCR, DCR and thing along those lines. I see that stuff being talked about all the time and I would like to understand more about it.
Old Mar 13, 2015 | 03:13 PM
  #1080
SRB02SS's Avatar
Martin feel free to post my # once it's tuned. I'll have some track et's and mph from Darlington Dragway soon I hope.
