Finally pulling the trigger on parts!
Old Jul 7, 2013 | 05:19 PM
  #261
LilJayV10's Avatar
Originally Posted by Martin@Tick
I guess my 235/243 111+2 doesn't make the cut....
Tooley is my buddy and all, but I just don't see that 460rwhp number being 100% genuine.
There is no magic cam that will give you 30rwhp more than what most combinations make even with a guy named Brian Tooley behind the cam specs.
I don't know. He had it on two maybe three different dyno's. Dyno jet was 460 and mustang dyno was 450. If there's more to it he didn't elaborate.
It was in a Z06, I don't know if the headers are a better design than a f-body or it dyno's higher because of the drivetrain setup. I have the dyno graph somewhere.
Old Jul 7, 2013 | 06:32 PM
  #262
JakeFusion's Avatar
Super Hulk Smash
I've seen that 460 number out of the G5X3 cams before. And any 234/242 or similar cam is a "G5X3" cam lol.
Martin, since my ptv is going to be close as it is, I'm definitely doing a bigger cam. I'm still debating the tuning, I might just go Polluter and get HPT and let Jonathan help me out with the tune.
Do you guys rent the tool out?
Old Jul 8, 2013 | 08:24 AM
  #263
427zm's Avatar
Jake, the right heads, as we've seen w/ Dr. Whigham, 460 can be possible. Below is a link to a buddy in our Vette group that has 471rwhp &440ft-lbs w/ non-ported 205 AFR's milled to 59cc and a G5X1-E cam. The G5X1-E was a reverse split cam that's pretty small. I don't believe LG offers it anymore, but here it created great power on this setup. With your build I don't see why you couldn't get there using a bigger cam. I probably should add, this Vette's LS6 does have less than 30k miles on it.
http://www.toquez06.com/
This is probably the cleanest C5Z in the country.
Old Jul 8, 2013 | 08:34 AM
  #264
JakeFusion's Avatar
Super Hulk Smash
Oh, I could hit 460 with the cam I have now and would pissed if I didn't. The bigger cams would be for a run at 500...
Old Jul 8, 2013 | 09:07 AM
  #265
Brian Tooley Racing's Avatar
Ouch, easy there buddy. LOL I agree that a degree or two here or there isn't going to make 30 rwhp, it probably wouldn't make 10 rwhp. Although in some back to back dyno testing that I had done recently, we found 10 hp by running .030" less exhaust lift. Although the seat timing is different even though the duration at .050" is the same so I'm sure that has some affect.
If you would like more info on the C5 Z06 that made 460 rwhp you can contact Andrew Rubio at Performance Motorsports in St James NY. I think his phone number is 631-366-2152. The C5 Z06 that made 450 rwhp on a Mustang dyno is actually a completely different car from here in Ky. You can contact DK Goodrich in Fort Knox Ky at 859-421-3334 about that car. I can tell you that he was very impressed with it.
I have several of my cams ground in bulk, I believe grinding them in bulk yields more accurate timing events.
Martin also sells BTR cams, isn't that right buddy?
Old Jul 8, 2013 | 09:09 AM
  #266
Sales@Tick's Avatar
It just seems like a high number for a LS6 intake and stock heads. C5's definitely have a much better exhaust lay-out than a F-body.
We probably could rent ours out, I'd have to ask though. I don't see it being a problem though.
I would love to do a big nasty Bullet Cam for you.
Old Jul 8, 2013 | 09:10 AM
  #267
JakeFusion's Avatar
Super Hulk Smash
The Stage 4 is ground in bulk?
Old Jul 8, 2013 | 09:47 AM
  #268
427zm's Avatar
That's what I'm talkin' about! Big overlap, meth inject it, and let it eat! Lets see 500+ rear wheel!
Old Jul 8, 2013 | 01:48 PM
  #269
JakeFusion's Avatar
Super Hulk Smash
Okay... ECU being sent off for a baseline tune and new cam on the way...
Old Jul 8, 2013 | 02:32 PM
  #270
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Well... That escalated quickly.
What did you get?
Old Jul 8, 2013 | 02:37 PM
  #271
JakeFusion's Avatar
Super Hulk Smash
EPS 234/242...
Geoff is going to set me up with a baseline tune then I'll go over to Baton Rouge for the final dyno tune.
Old Jul 8, 2013 | 03:57 PM
  #272
Rare96LT1Formula's Avatar
My god.
Are you legitimately making a run at 500 rwhp here Jake? Sure seems to me like you'll be in that neighborhood with the right tune.
Are you running a 10 bolt with stock gears?
Old Jul 8, 2013 | 07:12 PM
  #273
427zm's Avatar
Talk about changing an avatar quick! Can't wait for results!
Old Jul 8, 2013 | 08:01 PM
  #274
dr_whigham's Avatar
The Scammer Hammer
I hope you hit 500 Jake. That way I can bring you to tears when I break it...
Hopefully we can shoot over to State Capital Raceway after the tune and run em.
Old Jul 8, 2013 | 08:49 PM
  #275
JakeFusion's Avatar
Super Hulk Smash
I won't hit 500 with a stalled A4. But anything over 470 would be nice.
And sounds good. I'll get kicked out. Hoping for 10.8s or so full weight.
Old Jul 8, 2013 | 09:32 PM
  #276
427zm's Avatar
I like this suggestion. Do either of you guys have built rear ends?
Old Jul 9, 2013 | 04:38 AM
  #277
JakeFusion's Avatar
Super Hulk Smash
No, I plan to do an S60 after I break my 10-bolt. lol
Old Jul 9, 2013 | 05:34 AM
  #278
dr_whigham's Avatar
The Scammer Hammer
Same here. I'm gonna run it till it blows. I'll be getting an S60 as well though from Carl @ CRP. Only difference is my wife gave me permission
Can't wait to see how all this turns out brother. It's gonna be stout, that's a given.
Old Jul 9, 2013 | 06:28 AM
  #279
JakeFusion's Avatar
Super Hulk Smash
First thing I'm going to have to do is get the RPM Level 5 Trans.
Old Jul 9, 2013 | 06:30 AM
  #280
427zm's Avatar
I love it! Truly that's the right way to do a diff IMO! Fix it when it breaks!
