Finally pulling the trigger on parts!
Old Jul 9, 2013 | 08:21 AM
  #281
Brian Tooley Racing's Avatar
Originally Posted by JakeFusion™
EPS 234/242...
Geoff is going to set me up with a baseline tune then I'll go over to Baton Rouge for the final dyno tune.
Geoff will take good care of you, he's a good dude.
Old Jul 9, 2013 | 08:35 AM
  #282
JakeFusion's Avatar
Super Hulk Smash
Brian, I'm going to give you a call this morning after I get off this conf call. I need to rent the flycutting tool and head fixture from you.
Old Jul 9, 2013 | 03:40 PM
  #283
JakeFusion's Avatar
Super Hulk Smash
And so it begins...
But dammit. It is HOT.
Old Jul 9, 2013 | 03:50 PM
  #284
Rise of the Phoenix's Avatar
Good stuff here Jake. Can't wait till this thing's finished. I had to read through about 5 pages to get caught up
Old Jul 11, 2013 | 09:47 PM
  #285
JakeFusion's Avatar
Super Hulk Smash
Finally spent some time on the car today.
Radiator, water pump, power steering, throttle body, coil packs. All out. Fuel lines disconnected and emissions removed. Decided to take a break before going after the intake manifold and exhaust manifolds. Hopefully tomorrow I'll have both of those and the balancer off. Then i can pull the heads and front cover and get to the cam. Then I'll take the weekend to pull the trans and install the torque converter as well as the fuel pump.
PCM is out and on its way to EPS for a baseline tune as well.
Then hopefully the new cam will be here early next week and the flycutting tool will be available and I can make a run at getting it back together before next weekend.
Old Jul 11, 2013 | 09:54 PM
  #286
427zm's Avatar
Nice work Jake! So, are you working this week in addition to knocking this out?
Old Jul 11, 2013 | 09:58 PM
  #287
JakeFusion's Avatar
Super Hulk Smash
Yep. Slow pace and working on it as I can.
The most horrifying things thus far: passenger side rear bolt for the coil packs. And that bolt on the rear of the driver side head for the bracket that holds that AIR crap.
Something tells me the bolts for the manifold might one up them. I'm not sure there's enough room to actually pull those. lol
Old Jul 11, 2013 | 10:03 PM
  #288
427zm's Avatar
I guess this is why you see so many folks drop the cradle on major F-body motor work.
Old Jul 11, 2013 | 10:05 PM
  #289
427zm's Avatar
And what the hell is that line black can next to your A/C accumulator?
The F-body makes the Vette engine bay look like child's play!
Old Jul 11, 2013 | 10:41 PM
  #290
JakeFusion's Avatar
Super Hulk Smash
It's a pain in my ***. It's traction control.
Old Jul 11, 2013 | 10:51 PM
  #291
427zm's Avatar
gotta love the nannies!
So are you going to do meth here as well? You've got me eying the ECS kit daily.
Old Jul 11, 2013 | 10:53 PM
  #292
JakeFusion's Avatar
Super Hulk Smash
Eventually. I'll see how it does when it gets tuned.
Old Jul 12, 2013 | 05:26 AM
  #293
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
For the love of all things holy, do yourself a favor and do NOT reinstall those 2 rear coil pack bolts. You don't need them anyway. 4 each is plenty.
Good to see some progress!
Old Jul 12, 2013 | 06:16 AM
  #294
Blackbird-WS6's Avatar
I deleted all that ****. Looks 1000times better and easier to work on things.
Old Jul 12, 2013 | 07:14 AM
  #295
JakeFusion's Avatar
Super Hulk Smash
I'm thinking of pulling Trac and Cruise. I don't use cruise and won't be able to with a cam with 16 degrees of overlap...
Pulled most of AIR. Need to get that giant *** heater under the wheel well today.
Oh, and trust me, those rear bolts are not going back in.
Old Jul 12, 2013 | 09:42 AM
  #296
Rare96LT1Formula's Avatar
Nice progess thus far Jake. This is definitely one of the best, most thought out build threads I've seen. This should be an absolute monster once completed. Are you going to swap to an LS6 valley/run a catch can?
Old Jul 12, 2013 | 09:44 AM
  #297
JakeFusion's Avatar
Super Hulk Smash
I have the LS6 valley since it's an 02 (I believe?). And yes, I have a catch can. The amount of oil in the intake is ugh.
Old Jul 12, 2013 | 09:47 AM
  #298
Never knew that the 02 cars came with the LS6 valley. If that's the case, you're very lucky. I had to dremel part of my block to install that damn thing.
Old Jul 12, 2013 | 10:01 AM
  #299
handyandy496's Avatar
Those 10 bolts...Would strange axils and a spool work with your large tq numbers and whats the weight difference between stock 10" to HD 9" swap?
Old Jul 12, 2013 | 10:11 AM
  #300
JakeFusion's Avatar
Super Hulk Smash
There's no sense in upgrading the 10-bolt. Maybe if it was a bolt-on car, you could spend the money and try your luck. But I'm not driving a spool on the street. lol
10-bolt is the lightest. 12-bolts are maybe 30lbs heavier? A 9" is about the same but stronger. S60 is a little more than that, and somewhere between a 12-bolt and 9" in strength.
I like the S60. Good engineered solution that's good enough for most cars.
If you need a rear to withstand huge huge power, something like a MWC Fabbed 9" would be best.
