Finally pulling the trigger on parts!
Here are some pics:
Trans cooler hooked up (I've since pulled the straight fittings for 90 degree fittings to get the trans to sit in the tunnel - I was worried when I jacked the car and it wouldn't move that I busted the fittings, but everything seems ok. Guess I'll have to drive it under pressure and see if it leaks eep!)
And the AN fittings installed:
Decided to change the rearend fluid since it's all old and gross. In the process, I am going to put a TA Aluminum girdle/cover to try and help the 10-bolt out some along with some Royal Purple 85W-140 fluid + GM addictive.
This was the trans crossmember rubbing against the trans. BMR sent a new one and the new one doesn't rub nearly as bad. As soon as my brother is off from work we're going to loosen the motor mounts and see if I can't gain the 1/16" clearance needed.
Got the new seats installed after the first brackets sent from 6LE were welded upside down (and yes a 6-point rollbar is next if not a full 8-point cage).
Brakes finished
The 10-bolt may last on the street, but I don't know about the track. I guess we'll see. A Strange 12-bolt is on the list. Along with nitrous, the cage, tubular k-member and lower/upper a-arms to trim more weight off of it, and a few others things - like the stereo, some paint touch-up, and new tint.
And yes, the car is dirty. The problem with redoing your house while your car is in the garage near a lot of the sawdust.
