which cools faster oil or coolant?
just a theory question and no fans running after shut down.
Why are you wanting to know?
Alright... I'm 50/50. LOL
This would imply that as pressure increases, so does temperature..I think..not sure, always hated chemistry.
What about if I just put oil in a pan and coolant in pan then put both in the oven to under the coolants non pressurized boiling point then hit them with an ir and find out.
Like I said, too many variables in this equation to really do the math correctly. Thoughts??
Also, in an automobile, about half the coolant in the system is exposed in the radiator allowing it to cool, even without the fans or pump running. The oil is not exposed.
The oil drains into the oil pan where there is little air or oil movement to draw energy away from the oil. The coolant continues to flow through the radiator even after the car is shut-off, albeit slowly, thanks to free-convection from heat differentials through and around the radiator, this helps remove energy from the coolant.
in terms of what cools faster, that's dependent on thermal conductivity and the surface area available for convective heat transfer with the air. I think the coolant would win, though it's probably close because the block itself, being aluminum, is a massive heat sink.
We could throw out that water is technically a better heat conductor than antifreeze so that would suggest the mix ratio would play into the discussion.
What is the thought behind asking this question?
The oil and coolant are BOTH parts of the cooling system.
