Pics Of My Advanced Induction Dart/RHS 223cc Heads/Build Thread
#143
That wouldn't be enough for 7-800 rwhp.. The 340 is a little deceiving as I'm pretty sure it is not actually a 340lph pump. It is actually a 255lph pump but is a high pressure version. I've got Racetronix's new 340 pump and its great but I'm no where near 7-800 rwhp.
#144
Well, my dream is to build a turbo LQ4. I'm working on getting a damn near complete LQ4 here soon and then very slowly start buying things for it. I'll probably just get the Racetronix kit and call it good for the time being because this turbo build of mine won't see completion for several years.
#146
The newer Aeromotive and Walbro 340 lph pumps are rated to 340 lph at free flow, just like the older 255 lph pumps are rated to 255 lph at free flow. Don't confuse the older Walbro model number GSS340 with a 340 lph pump, it is only a 255 lph pump.
There are tables out there of pressure vs flow vs voltage if you search around. IE, here is one:
http://realstreetperformance.com/sto...on-test-5.html
A long time ago people got around the inability of intank pumps to supply enough fuel by running both an intank and an inline pusher. The intank supplied the volume and the pusher supplied the pressure. A 255 intank pump feeding a 255 inline pusher was good for 700+ rwhp back before the invention of the huge capacity and high pressure intank pumps. Now fuel systems have gotten to be so overkill, not many people trust what worked 10-15 years ago.
However, back then in my race car, I ran a Weldon 2015. My street cars all had Walbro 255s and pushers.
#147
I just got done e-mailing two shops in the greater St. Louis area that have dynos. The first place I e-mailed was Craven Performance. I checked out their website, but it doesn't give details on what type of dyno they have (not that it really matters). They'll do $75.00 for 3 pulls. I then e-mailed Mustang Muscle Performance, as they have a DYNOJET dyno and offer the same type of service, but they don't have prices on their website. They do, however, indicate on their website that they are the only shop in Missouri with the DYNOJET Wide Band Air Fuel Monitor, which lets them measure and print on the dyno sheet the air fuel ratio throughout the entire RPM range. I had planned on going to KC for the dyno time, but St. Louis is much closer to where I live. Has anyone used either of these dyno's?
#152
Just saying. You have a tuner already in mind? Your just looking for a dyno to rent? Just ask around all the locals. Usually big shops like craven will charge an arm and a leg for anything. Locally IIRC normal going rate was $100-150 first hour and $25-50 after that. I can't remember though. Doesn't have to be a mustang or LSx shop just find a dyno and rent it. If thats what your looking for.
Edit: A simple google search brought up dyno jets in your area.
http://www.dynojet.com/maps/autodynos/mo.htm
#157
Yeah, I've got e-mails back from the one place in the STL area; $80 for 3 pulls with print-outs and air/fuel readings. It's the mustang place in St. Louis that has a dynojet. Dirtbag on here suggested Redline Performance in St. Louis; $50.00 for 3 pulls with print-out and air/fuel. Looks like that's who I'll go with.
