New JD motor lets go after only ~1500 miles
#181
Originally Posted by 7DMACH1
When I listen and watch the video, it sounds like the driver missed second gear. Listen to it and listen to the rpms. Just my .02. RAY
I think the audio was pulsing in places..listen to the pulse even before the launch...I think it did the same with it was at the top of first. I don't have a real camcorder...this was done with a digital still camera....that has some recording capability...
#182
Ez, turn the volume up. I know the difference between a car doing a burn out and a car going down the track. Was he double clutching it like a Mack truck? No he missed second. Why does the other car fly by him at that point? Because he missed second!!!!
I have several people that watched that run in person (including the owner of the car) that will attest that the car DID NOT miss a gear. Not sure what the audio heard was...but it wasn't missing a gear...
#183
Originally Posted by VINCE
I agree with you to a certain extent. We do have engine builders on this board who stand by their work. With all the problems ARE had in the past they still held up to their part when 383LQ4SS lost his NITROUS motor the first and the second time. The sole purpose of paying a premium price is to get some kind of security. Why would I pay $3k to $7k for a shortblock with no warranty when I can have some local nobody build the same motor for less and get no warranty?
Chris
ps- With a poweradder motor most warranties go right out the window. If you spray it or super/turbocharge it you are on your own.
#184
Shorty Director
Originally Posted by Chris ARE 360
AFAIK there was nothing wrong with the ARE motor. The tuner (NOT ARE) had the knock sensors turned off!!
Chris
Chris
#185
Vince,
I understood what you were saying BTW on poweradder cars ARE will support and continue to look after even those cars. they do have a limited warranty even on those. That's not to say they would replace an entire motor but they would help out to get things back to top condition.
#187
Originally Posted by ezss
I didnt have any power adders, but the tuning done by PCMforless did turn off my knock sensors because I kept getting a flashing SES.
#188
My misfire has been turned off for awhile. One day I will tweak the settings so I can turn it back on. How would you delete the knock sensors? Just the SES codes or setting all the knock setting to 0? both?
#190
Knock retard and misfire index are two different animals.
Many cars have large cams and as a result their misfire index is very high. Many tuners will turn that function off, as it is an emissions issue and won't harm the engine. When the PCM cycles it records every misfire and if the during a certain cycle it records an emissions fault it will set a code. The code can be annoying and with large cams a fact of life, hence the resaon to turn it off.
The knock sensors on the other hand protect the engine from lean conditions, fuel issues and various weather conditions that exist. The knock sensors will detect ping and begin to retard timimg in an attempt to bring the engine back to normal parameters. By turning them off the engine can no longer sense and recitfy those kind of problems which can dramatically shorten the life of the motor. You can desensitize the knock sensors but turning them off is very bad.
#193
I thought it was he deleted the misfire, then disabled the knock because it was somehow triggering the misfire, which since it had been deleted couldnt fire a real code so it kept flashing but produced no code when ATAPed. Could be wrong, Im not going to say Im sure on this one because im not.
#194
Originally Posted by onyxxtreme
is 7DMach1, actually JD?
he sure does seem to like the way JD's *** tastes the way he's been kissing up to him this whole thread
#195
Ive listened to that video several times, the car sounds like its knocking before he launch's. Definatly was something wrong with that motor. My 396 that Alan built got about 10 missed gears thrown at it last sunday, im not pointing any fingers at the driver of my car, but his initials were "CamminBeaSSt" aka Ron Mowen. haha sorry had to ron, but back to the point, even a missed gear or 2 or 3 or 4 or 5 for that matter shouldnt pop that motor at only 1500miles.
#196
#198
Shorty Director
Originally Posted by Warbird
Vince,
#200
Updated Video With Fixed Audio
ok...there was a problem with the audio when I did the conversion from mpg to avi.
here is a bigger mpg file (straight from the camera). Note the pulse is gone during the staging and the 1-2 shift is nice and clean
Please right click and save...its 5.2MB
http://home.comcast.net/~bkrzewinski/kaboom.mpg
