5.3L TEA 1.5's going on soon...gaskets, tuning questions.
!LS1 11 Second Club
Just wrapping up my list....
1) Head Gaskets.
Which GM # is correct? Do I use stock GM LS1 heads for 5.3L heads?
I have a few part numbers:
12558809 (driver)
12558810 (passenger)
12498544 (is this a kit?).
Which number do I need to walk up to the parts counter and say "give me these..."?
2) (New) Stock LS1 GM TTY head bolts should be fine?
I got the part #'s from ls1howto.
3) Tuning.
I'll be installing the heads at my house and will drive the car about 15 miles to get it LS1Edit dyno tuned for the new setup. I will not be able to adjust anything for the higher compression during that drive. Should I consider having the car flatbeded/ transported there, or can I safely drive the car with the new heads to the shop without worry of timing issues? I don't know how much timing my current tune has for the cam-only setup.
Thanks in advance,
SouthFL
1) Head Gaskets.
12558809 (driver)
3) Tuning.
Thanks in advance,
SouthFL
I've used stock MLS gaskets, graphite gaskets, and aftermarket Victor gaskets. Any of them will work fine. The best $$$ value out there is the Victor's from NAPA, I've ran probably 6 sets of those without a problem. I'd grab me two of those for $10 each and a set of bolts and you'll be ready to go... BE SURE to clean the block deck and also to remove ALL coolant from the block bolt holes before installing the new heads. Let us know how it turns out.
btw.. your tune will be fine now further than you have to drive it.. just don't hammer on it too hard till it's tuned with the heads.
Enjoy the new power!
!LS1 11 Second Club
Gomer, would you happen to have the part # for those Victor gaskets? Are they the same thickness as stockers?
As for cleaning the bolt holes, paper towels & patience, I know, but will a shop vac speed up the process?
Thanks!
Thanks!
Thanks!
foff... they list the same part number of head gasket in the Victor catalog for 1997 thru 2004 LS1's.
!LS1 11 Second Club
A friend of mine had an extra set of 12573949 gaskets which he just gave me. These I believe are the GM MLS gaskets for 2002+ LS1's. Can I use these with the 5.3 heads? Are they the same thickness as the GM graphite gaskets? Should I check the TEA heads for a notch or something? Head gurus help me out please, I'm having gasket anxiety.
!LS1 11 Second Club
I just read in an old post that:
Will such minute differences affect compression ratio to the extent that I should go with the graphite gaskets? I now have both the GM MLS and the NAPA Victor Gaskets mentioned earlier in this thread. Which ones should I use?
GM graphite gaskets are ~.054 compressed, and MLS are ~.060.
