1.7 rockers to 1.85 rockers
I am running the Texas gaint cam, 317 heads with Precision Race Components .650" Double Springs and the stock rockers w/7.400 rush rods
I was looking at the SLP 1.85 rockers
Just on ratio alone the lift exceeds the 0.650" spring. I come up with 0.676" lift on exhaust and even if the valve train could be controlled and even if the springs would handle the lift, I doubt there would be any performance benefit or at least not enough to warrant the expense. And if you are running stock rockers, I would hazard a guess the rocker tip would go over the edge of the valve stem unless you really spend time setting the rocker height. Even then it may not be correctable.
since we are on the subject about cam size with these 1.85 or is it 1.8 rockers. i had them on my ls1 with 224-224 cam, then transfered them on my 402 with cam 236-242 .650 lift total, now with 10000k on my dual gold springs i have to change the springs(lost 1000rpm). i have a set of brian tooley spings on the way, going to change them this winter. do you think the rockers are ok with my cam, would like to keep my rockers(adjustable,studs guide plates, push rods, nice kit) or else have to spend another grand to get the 1.7 crane rocker kit
Guys need to stop blindly applying gen 1 knowledge to gen 3s. Gen 3s come with a lot more rocker ratio than gen 1s did. It is possible to use rocker ratios 1.8 and higher but only if the system is well thought out by a true professional, and buying shelf lobes and blindly throwing ratio at them is not well thought out.
i would have not bought them to add to my present cam, the cam is healty enought for my engine, i like the ideal that this kit is able to adjust the valve train and did not want to lose the investement i had in to them. was wondering if the rockers are going to ruin my new springs or am i ok.
