My build 396 cid on E85 w/ 14:1
#204
I like your build, curious about the compression and how the Dyno will react since this is not a "Copy build" you can "Tune it a bit" for the street. I especially like the E85 for non-DD'ers lots of potential for seat of the pants grunt from Sky High compression.
Enjoy the ride, this will be a fun car.
#205
#207
Question, can 3/8 thick pushrods fit in 243s without machining?
#210
I would e-mail him right away then so he can have the heads machined, if they need to be, for the pushrods. If they do need to be machined, I would seriously have him do it for free since you're spending so much money with him already, and the heads aren't getting done as soon as they expected.
#218
So my pistons should be here Friday as well as the block. All I need engine wose then is rod/main bearings but Tick Performance should have those on hand. I am also going to go with head studs so I need to buy those as well. The last thing I need for the car to run is the braided stainless steel fuel line for the dual 255 pump I bought off a member here which should be here in the next week or so. If I have enough funds I am going to get a Extreme Automatics 4l60e otherwise I will baby it until I can.
#220
Also I am trying to decide on whether to drop the tank and remove the pump and fuel that way or cut a trap door and siphon the fuel out with a pump, I don't believe there is much left in it.
![](http://i737.photobucket.com/albums/xx16/98TransAmWs-6/446210d1397066467-98-dual-walbro-sending-unit-nasty-performance-rails-magnafuel-boost-fpr-more-image-2158026482_zps75510e4e.jpg)
