what cam should i buy?
i havnt decided on heads yet but it will be:
tfs 215
prc 215
ported ls6
my goal is to get as strong as i can all motor and at some point a little spray
these are the cams m looking at!
Texas Speed Magic Stick 3 237/242 .603"/.609" Camshaft
Texas Speed Magic Stick 4 239/242 .649"/.609" Camshaft
Speed Engineering "The Terminator" Camshaft 238/242 .605"/.610
Speed Engineering "SS-230" Camshaft 230/230 .592"/.592
Speed Engineering "X-Rod" Camshaft 234/236 .598"/.602
any advice/opinions/recommendations on these cams or other options are appreciated.
tfs 215
prc 215
ported ls6
there is a few guys that post here alot that spec cams ,i would give them a call and see what they say, martin at tick, pat g, cam motion and texas speed just to name a few... it seems there is alot of different options that make power.
ive heard martin @tick and pat G a few times...... is that their member names on this board?
Martin@Tick
or www.TickPerformance.com
I'm actually going to be ordering my cam from Tick in a couple of weeks.
tfs 215
prc 215
ported ls6
tfs 215
prc 215
ported ls6
They are different. The cam made for Nitrous should work better with Nitrous but a little weaker with out Nitrous. The cam for NA no Nitrous will still work good with Nitrous but should run a little on just motor alone.
Do you want the cam that works the best without Nitrous? Or do you a cam that works best with Nitrous?
as i said i want it to be beastly without nitrous and still be decent with it...nitrous will be my last addition
When a customer asks if their cam needs to be biased towards nitrous use I ask a few questions to get an idea of how often they will be using nitrous, and how much nitrous will be used each time.
If a customer isn't spraying his engine every time he uses it at WOT then IMO there is no need for a "nitrous" camshaft. Especially if that amount of nitrous isn't over 200-250hp.
Based on the cams you've mentioned, I feel you would like our SNS Stage 3 camshaft. Its specs are 235/243 .621/.624 111+2.
I am a big fan of TEA TFS heads, and the 215cc castings are proven to make power. Those heads and the SNS 3 would make a strong running combination.
We can't, or at least shouldn't, give anyone a hard time for reviving old threads. Badmaroonz28 probably used the search function and was shown that/this discussion based on relevance to his/her search.
To badmaroonz28,
Ask tick, or Martin, or pat g directly via phone or email or private message on here. Asking the general population will get you a bunch of answers from a bunch of desktop "professionals"... Or you can actually ask the actual pro's directly. It's your choice.
To badmaroonz28,
