Cam Motion needs cam names can you help
OK guy's Cam Motion needs help. We will be adding to our web site very soon. We will have drop in cams for most C.I. LS engines with required parts for a cam change. We will have a Spec sheet to fill out for special combinations. We will also offer shelf cams with not much description as do most company’s. These cams need names. It seems that people like to call their cam by a name like FNS or Big Bad ***, Monster Grind, Ball Buster, Stage 47, The Big showama, With Yzoom lobes that are so fast they will give you 75 extra HP, RPM to 8000, and be easy on the valve springs .So if you have some good names you think would help us, please let us know. If we use your cam name we will give you a good discount on any order you may have with us in the future. Thanks, Cam Motion
Super Hulk Smash
They should have a Cajun flair to then names...
Fais do-do - sleeper grind
Lagniappe - smaller grind
Arrete - The "stopper" (for stopping those ricers on the street?)
Freesons - The goosebump giver (big stick?)
Cooyon - Stupid/crazy (biggest grind) Edit: my wife tells me the correct spelling is "couillon."
Kip - Cooyon or Koo-yon would work since that's how you say it.
The following users liked this post:
hefftone (09-05-2021)
