L33 OEM cam? If not, what cam is this?
Last nite I decided to take the cam outta my 06-07 L33. When I bought the engine I was told the cam that was in it was a decently aggressive cam from TX Speed. After getting the cam out I realized the cam is an OEM cam but I'm having trouble finding out which cam it is. The numbers are:
3207
1 03
6349
Is this just the stock L33 cam? If not, which cam is it? I tried to search the number but had no results. I'm alittle disappointed it isn't the TX Speed cam like I was told but I can use the LS2 cam that came extra with the engine for now. Can anyone tell me what cam this is and what it came out of? Any value to it? Just curious as I haven't found any info.
3207
1 03
6349
I think I have the info you're looking for...
2005-2007 L33 camshaft part number is 12583623.
You have camshaft part number 12593207. This should be a Gen IV cam, and was used in the LH6 engine (among others) which is also an aluminum block 5.3L. You may not have an L33 - the LH6 is often mistaken as an L33. Dead giveaway for the LH6 is the AFM lifters and valley cover, and the timing cover mounted cam sensor.
Anyone else have any experience with an LH6?
