To balance or not balance??
My car was originally a M6. Which means it had a heavy *** flywheel. Now that it's an A4 it has a much lighter flexplate. Which it didn't get balanced after that change.
Also, I'm keeping the stock crank and rods. The only thing changing internally is the pistons and pins. Still stock bore pistons. I'm changing the stock pistons for the Mahle Forged pistons.
So my question is this. Is it worth the money for the balance? From what I've found there is only 6 grams difference between the piston weights with the new ones being lighter than stock.
It may be a stupid question but I have to ask.
I looked up 48 grams which is what the total difference in pistons and pins would be. 48 g = 1.69 ozs lighter than stock pistons. That , spread over the entire engine, doesn't seem like much but at high rpm's I guess it is. I talked with the machine shop yesterday and they said it would be balanced to within 1/2 a gram.
Then, along comes 48 grams less, distributed in a different manner than the above. A rebalance would be imperative.
Conversely to paragraph one, let's say that the previous version was not balanced. Still, reducing your assy by 48 grams would still require a rebalance.
6 grams static unbalanced = 29.39lbs of unbalanced rotating weight.
50 grams static unbalanced is 244.97lbs of unbalanced rotating force. That is significant.
What needs to be specified is 50g unbalanced at what rpms. If it's 50g at 6000rpms you are golden. If it's static it is really bad.
If it's 50g at 1000rpms, that is about 50 G's at 1000rpms with a 3.66" Stroke, comes out to 1gram static unbalanced weight. Or 4.9lbs at 6500 rpms.
For those that care, the equation for rotational g-forces is:
RCF = 1.118 * (10^-5) * r * (rpm)^2
Where:
RCF = Rotational Centrifugal Force (G-forces)
r = radius in cm
(rpm)^2 = revolutions per minute X revolutions per minute
16 oz per pound
28.3495 grams per ounce
Or 453.592 ( I round up to an easy to remember 454 grams per pound)
I had mine balanced to 9.5 grams at 1500rpms (or about 0.09grams static and about 0.412lbs at 6500rpms).
