Any EPS 230/238 w TF 220s out there?????
I haven't seen many of this exact combo out there as far as results go maybe I missed them in my search just wanted to know how that combo ran, dyno numbers, track passes or just comments on the setup in general.
Very similar combo being put together at the moment 230/238 cam except its not an EPS cam and the valve events are probably different than most would run and hand ported dart225 heads. That setup is really good if you do some cleanup work on the heads and the cam is good if you don't go with a large LSA. Well say this setup is on LS2 or larger motors. If you can't make 450+ to the tire with this setup your doing it wrong any trans and rear end combo.
I've seen eps 230/234 with advanced induction 243s make 460rwhp,also 228/230 with tfs 220 make same power so I think you will be in the 440-460rwhp but regardless what the rwhp is I think it would make a good strong set up
When I spoke to EPS briefly they recommended the 226/234, with the cast 220s. Yea I see that cam a lot in LS2s guessing because of the extra displacement. Im going to get them touched up by BTR before there shipped out. I was also curious as to the valve events I read somewhere that if you have really good flowing heads you don't need the extra on the exhaust side.
Having one hand in the pot so to speak is really the best way to go. Since Brian is hooking you up with the heads and valvetrain components, makes sense to have him spec out a custom stick with all the correct valve events for those heads, as well as how you intend to use the car and desired power levels. I'm looking forward to seeing how this all turns out for you.
I agree with the calling BT or Geoff at EPS posts but in my humble opinion I dont think you're going to get a cam with that big of split. Big split cams are usually reserved for heads that dont flow as well on the exhaust side like stock ones. Once ported or aftermarket heads come into play you can cut the split down a little and not lose anything. Just my .02
