Wiseco stroker piston rings
The second is I'd like to see if anybody has any tricks on installing the support ring, two scraper rings and the expander into the lower oil control groove. The scraper rings are a larger diameter than the groove and the expander seats itself tight into the groove. It's hard to sandwich the expander between the two control rings. The scraper rings want to ride over the top of the expander on the side that's pushed out. There must be some easier way.
Then, take one scraper ring, install it on top of the expander in the top groove first. Start the scraper's ring-gap approximately 1 inch to the left/right of the expander's ring gap. Then take the second scraper ring, and repeat the process on the lower portion of the expander ring.
The scraper rings ride on top of the expander and hold it in place.
The trick is to wrap the scraper rings on without using any force. Otherwise you'll pop one side out and overlap the expander.
Hope this make sense.
Yes, the raised part of the dimple points down in the pin bore. The dimple stops at the piston preventing it from rotating around the piston.
I have 3 sets of brand new oil rings if you want them.
I had problems gapping an entire set for my build, and purchased 4 brand new sets to start over. They're about $25 bucks each, if you want them, I'll mail them to you for nothing.
EDIT: I forgot about the bore size. Mine are for a 408, 4.030" bore.
Part number: 4032GFX
