Tick SNS Torquer Stage 2 users Come On In!
Old Sep 28, 2014 | 02:03 PM
JakeFusion's Avatar
Super Hulk Smash
Originally Posted by Martin@Tick
DA is a killer. 99.42 is his corrected MPH and 7.27 is his corrected E.T. to sea level. That is for mildly modified engines according to Wallace. 97mph is extensively modified engines and 7.36 ET.
Seems about right to me.
Yeah I plugged into Wallace to see. That seems about right given his power. DA plays hell.
Old Sep 28, 2014 | 06:40 PM
Mark01Ws6's Avatar
Bluebird, nice video. I've been looking for someone running this cam too. Most m6's opt for the ls1 version. Any reason you went with the ls2 grind in particular?
So far I haven't found anyone on here running this cam like I will be. Looking forward to providing some helpful numbers to add to the database for anyone thinking of a setup like this on an A4.
Old Sep 28, 2014 | 06:59 PM
BlueBird346's Avatar
Pretty much just wanted to go a little bigger. It didn't lose any low end but I think the car would benefit from steeper gears. I can drive in 6th at 1100 rpm with little to no cam surge.
Old Sep 29, 2014 | 08:50 AM
LS1nut346's Avatar
Bluebird/Mark, do you guys know what your PTV is with this cam? Did martin mention about sacrificing any PTV over the LS1 stg 2 cam?
Old Sep 29, 2014 | 09:29 AM
Mark01Ws6's Avatar
No idea. I don't recall Martin saying anything about PTV sacrifice vs the ls1 version. I'm sure he could give better specifics on PTV on stock 241's with this cam.
Old Sep 29, 2014 | 09:31 AM
Rise of the Phoenix's Avatar
With the SNS Torque Max Stage 2 cam and my AI Dart/RHS heads, I had something like .060 intake and .101 exhaust clearance.
Old Sep 29, 2014 | 09:32 AM
Where is Bluebird's video? I don't see one.
Old Sep 29, 2014 | 09:48 AM
Mark01Ws6's Avatar
Do a search on Youtube for Tick 231/235. Came up close to the top. I actually saw the clip minutes before finding this thread.
Old Sep 29, 2014 | 12:38 PM
I had .070/.085 but my block has been decked .008 and heads shaved .006.
Old Sep 29, 2014 | 09:54 PM
LS1nut346's Avatar
Good to hear. So basically your quench is similar to running a cometic .040 gasket with a stock deck. Good to know PTV with that setup and your cam should be good.
Mind posting your dyno graph??
Old Sep 30, 2014 | 10:58 AM
Yea I was going to go with the .040 until we decided to deck the block.
I'll try to post my dyno sheet tonight, but no promises, been pretty busy lately.
Old Oct 1, 2014 | 11:51 AM
  #32
Sales@Tick's Avatar
The LS1/LS6 SNS Stage 2 and the LS2 Stage 2 both open the intake valve at the same piston position (6.5 BTDC@.050) and close the exhaust valve at the same piston position(4.5 ATDC@.050).
The LS1/LS6 Stage 2 has a 107 ICL and the LS2 Stage 2 has a 109 ICL. Even though the LS2 Stage 2 has a 231@.050 intake lobe vs. the LS1/LS6 Stage 2 227@.050 intake lobe, the 109 ICL yields the same amount of valve lift@TDC during overlap with a 231@.050 LSL lobe as a 107 ICL with a 227@.050 LSL lobe.
This means that on paper both cams should have the exact same amount of P to V.
Old Oct 1, 2014 | 05:33 PM
  #33
laurentj23's Avatar
How's this cam do over regular daily driving ? And how much mpg does it affect? I'm planning to put this cam on my setup.
Old Oct 1, 2014 | 06:56 PM
  #34
If the tune is good, it will drive perfect. I don't have any issues driving it, and while it's not my daily, it very easily could be. In regards to mpg, my tuner has my tune setup to run pretty lean at partial throttle and cruising, so I get good mpg's.
Old Oct 3, 2014 | 02:57 PM
  #35
Mark01Ws6's Avatar
Ok cam update.
Cam sounds great. Initial results are in. 330 hp with converter unlocked on a stingy mustang dyno.
Long and short of it , I ran out of injectors. Was hitting 12.9 afr at 6200 and 105% duty on injectors. Looks like I need to upgrade fuel system to see full potential. Just not in budget atm so I'll have to wait and gather funds to finish it right.
All said, as it sits I think the power is about right atm. Just need to bring fuel supply up to par and I think should see another 15 to 20 in it. Probably go with about 42lb injectors.
Old Oct 3, 2014 | 03:06 PM
  #36
Ok cam update.
On my setup, even with the Accel 44lb/hr injectors, my pump (stock for now) still needs to be replaced because fuel pressure was dropping to around 44 at WOT around 6500 rpms.
Old Oct 3, 2014 | 05:18 PM
  #37
2002 blue z28's Avatar
FWIW i'm running 36lb injectors and stock fuel pump without issue. Inj. duty cycle was around 70% IIRC.
Old Oct 3, 2014 | 06:04 PM
  #38
I'm on FAST 36s and a racetronix pump. Not sure what the duty cycle was at but I think it's plenty of injector for my setup.
Old Oct 3, 2014 | 06:32 PM
  #39
I've always been told that even with bigger injectors, the stock fuel pump is only going to be good till about 450 rwhp.
Old Oct 5, 2014 | 09:07 AM
  #40
laurentj23's Avatar
How's this cam on dd guys?. I'm planning to put this on my build which is gonna be my dd. What mpg do you all get? And no..I don't want to drive a Honda.
