5.3l Cam Ideas
What I'm thinking right now after doing some reading is that a 5.3l with a cam might be what I'm looking for. (there are a ton of 5.3's in the junk yards after all)
I'm guessing the car will probably weigh around 2800lbs when it's all built (the weight of the V8 Monza), so I won't need as much engine as a Camaro or Vette would to get the same results. The car is also emissions exempt.
My research so far has me looking at the Comp XR281HR. Have any of you run this cam (or similar) in a 5.3l with the stock head ports? (and valve springs, headers and a decent intake of course) What numbers and drivability did you get? I'm guessing it would generate around 380rwhp at sea level.
With the right mix, you could knock on the door of your hp goals.
As far as et/mph that's gonna have a lot to do with converter,gear, and tire size.
More information will help guys here give you more accurate responses and help guide you where you want/need to go.
But please do yourself a favor and order a cam from a vendor who sponsors the site and does not use Comp cam cores which are prone to failure.
Cam Motion is my go to but Engine Power Systems (EPS), Martin Smallwood, and Brian Tooley racing can all spec you a cam and get it ground on a Cam Motion core for you.
Texas Speed now uses Callies cores which I'm not familiar with but are probably still much better than Comp.
Any of the above will be a better product, have better customer support, and should come with a Cam Dr report showing your cam is ground correctly.
The typical price is only $50 more which is a bargain compared to replacing a $400 cam and a $100-150 set of lifters.
206/206 .560/.540 114+4
217/225 .637/.620 114+3
224/228 .604/.595 112+2
226/230 .612/.603 111+2
230/234 .612/.595 111+2
I'm thinking that 224/228 cam will be close to what you want for that little car.
Martin uses cam motion cores, which are about as good as it gets, so I would stick with Martin Smallwood or cam motion for your cam.
The power stroke also becomes important on a limited atmosphere deal like this one. Since there will be less air/fuel mixture trapped in the cylinder due to the loss in atmosphere at your altitude you will also generate less cylinder pressure. For anywhere close to the same amount of work to be put to the crankshaft on the power stroke with this loss in cylinder pressure, the exhaust valve cannot open too early. This later opening event will help to make back some of the torque you will lose at your altitude from the loss in cylinder pressure.
The last thing that must be altered is the length of the overlap event. Overlap can lose charge to the exhaust system at low engine speed. This takes away from the air/fuel mixture that could fill the cylinder resulting in more low speed torque production. Since you are already working with less atmosphere to begin with, any loss in air/fuel mixture to the exhaust system really hurts your bottom end torque production. Because of this overlap must also be limited somewhat versus an engine running at sea level.
If you would like a recommendation for a cam, and possibly order it from me I would be glad to help you choose the proper cam. I will need to know a little bit more info though.
If you'd like you can call me, email me or PM me here on tech and I'll be glad to assist with your cam selection and any other engine/valve train related questions you have or parts that you will need.
Hope this helps!
Once again, Martin, thank you for the science lesson. I always love how informative your explanations are.
It would actually be an earlier IVC event. Since there is less charge inertia due to the intake charge having less mass, cylinder filling will diminish sooner on the compression stroke.
I like to explain charge inertia as a rock rolling downhill. The taller the hill and the heavier/larger the rock is the more inertia(momentum) the rock gains as it rolls downhill. Think of the rock continuing to roll even after the hill flattens out as the cylinder filling that occurs once the piston reverses direction and heads back towards TDC on the compression stroke. Just because the piston is no longer travelling down the bore creating a depression in the cylinder in which atmosphere can then fill, doesn't mean that cylinder filling doesn't continue to occur. Due to the inertia created on the intake stroke, cylinder filling on the compression stroke (known as inertia ram effect) continues to occur even as the piston starts to compress the intake charge.
There will come a point though where charge inertia is overcome by cylinder pressure. At this point it's time to close the intake valve to trap the maximum amount of air/fuel mixture in the cylinder as possible.
No problem sir! Just trying to spread some knowledge!
In my sticky "Why LSA doesn't matter", I explain how to harness exhaust scavenging and pressure wave tuning in the intake port, and how to turn it all into additional volumetric efficiency.
