Heads/Cam Swap Parts Suggestions.
Hey all, getting ready to do a heads/cam upgrade so I figured I might as well upgrade the other essentials along the way. I wanted to compile a list and see what kind of input I can get. For reference, car is a 00 SS M6, TSP 1 7/8" headers, 3" Rumbler Dual Exhaust, Stock 243 Heads w/ Lunati 660 springs , Com Cams XFI-XE-R 281HR Cam.
Parts I have in mind to upgrade:
New lifters, 5315 Morel's or the Comp Cams "Comp R" for 20$ more.
Lifter Trays, LS1 but I read LS2 might be a better choice?
Rocker Arm Trunion kit
Timing Chain, LS2?
Oil pump, Melling High Volume or TSP ported LS6?
Intake, FAST 92mm and 92mm TB
Under Drive Pulley perhaps?
Balancer, Suggested ATI or Powerbond.
Should be a whole different animal after all is said and done
Timing Chain, LS2?
Did you do anything to the LS2 trays? I hear you have to drill holes in them for proper oil flow. Differences between an LS2 chain and LS1?
The ls2 chain is a little more heavy duty compared to the ls1, ls2 chain is cheap insurance.
http://www.summitracing.com/parts/tfs-k30675600
This one specifies its for ls2/ls3 but the reviews say the guy bolted it to an ls1
http://www.summitracing.com/parts/tfs-30675600
This one specifies it is good on any LS block. The parts look identical but this last one does not have the tensioner included.
I want to say the first one is correct going off of reviews and that it looks identical to the second one.
I was actually looking at them on there already but which kit is it?
It will work on Ls1's also since the bracket bolts to the cam retaining plate.
