First LS build
Old Aug 20, 2016 | 07:04 PM
madsv1000's Avatar
Originally Posted by Tuskyz28
Looking good!! What cam you plan on running ?
A XFI RPM HR cam is what comp specked out with
.220/.224 @ 50 and a Valve Lift of .530/.534 @ 50 on a 114 LSA.. But I'm going to ask the guy we deal with from comp at work and see what he says.
Old Aug 23, 2016 | 11:20 AM
madsv1000's Avatar
Got my block back from cleaning this morning looks pretty good wiped the cylinders down with some oil to keep them from rusting. Now time to take it into the shop and start taking measurements.
Old Aug 23, 2016 | 12:08 PM
ss454327's Avatar
I would get a cam spec'd from Cam motion or one of TSP's new grinds. Give them those head flow numbers and your goals.
Old Sep 3, 2016 | 09:53 AM
madsv1000's Avatar
Brought the block into the shop this morning to get ready for machining next week and clean some more. Pressed the wrist pins off while I was at.
Old Sep 3, 2016 | 10:29 AM
madsv1000's Avatar
Before cleaning
After
Old Sep 9, 2016 | 09:33 AM
madsv1000's Avatar
Dang went through a few of the rods and the id on 5 of them were 3,4,5 tenths over sized. You can see where the bearing was moving a bit in the photo. I was hoping this spare set I had would be good.
Old Sep 13, 2016 | 05:11 PM
madsv1000's Avatar
Ordered lifters and lifter trays from TSP today. All that is left to order in the cam, rods and gasket set.
Old Sep 13, 2016 | 05:21 PM
06gtoLD's Avatar
Nice, any ideas for your new cam? Good luck!
Old Sep 14, 2016 | 11:16 AM
madsv1000's Avatar
Thinking of using something from comp. Like 226/230 on 112 With those being the LXL lobe from them.
Old Sep 14, 2016 | 06:54 PM
KCS's Avatar
KCS
Moderator
Have you already resized them?
Old Sep 14, 2016 | 07:32 PM
madsv1000's Avatar
I haven't done these. They were a set from another block I bought a few years back. You can't resize broken cap rods anyways from what I understand.
Old Sep 14, 2016 | 08:40 PM
  #32
KCS's Avatar
KCS
Moderator
Sure you can. You just hone them about .002" larger. All the bearing manufacturers make a bearing for the .002" oversized housing bore. You don't even need to cut the parting surface.
Old Sep 15, 2016 | 12:54 PM
  #33
madsv1000's Avatar
Tested the flow rate on the injectors. Making sure they were still flowing the same.
Old Sep 15, 2016 | 03:12 PM
  #34
psychosid30's Avatar
Good lord! I just want access to the tools you seem to have available to you!!
Old Sep 15, 2016 | 03:44 PM
  #35
madsv1000's Avatar
Perks of working at a racecar manufacturer.
Old Sep 17, 2016 | 06:03 PM
  #36
madsv1000's Avatar
Went into the shop this afternoon to clean and check the spring install height and seat pressure. Got the install height 1.850, but the spring tester wasn't working for me. So I'll have to retest agian Monday. And I'm pretty sure I was not using the height gauge right. I did put the heads in a solvent bath for about an hour just to make sure they were really clean.
Old Jun 27, 2017 | 06:17 PM
  #37
madsv1000's Avatar
Pulling this thing out of the mothballs. Finally got around to checking on the valve spring install height they were damn near dead nuts 1.800. Got the guys on in the engine shop to check the spring rates while they were helping just to see for kicks a giggles.
Old Aug 22, 2017 | 06:33 AM
  #38
madsv1000's Avatar
Just slowly coming along. Decided to crack test the crack this morning just to be on the safe side. Zero cracks turned up and it looked good.
Old Aug 26, 2017 | 10:18 AM
  #39
madsv1000's Avatar
Went into the shop this morning and ported and shimmed my oil pump. Amazing what a few minutes of work can do for the entrance and exit of it. Rods came in yesterday and bought a set of pushrods to go with the cam I've finally settled on. 227/235 @ .050 .614/.621 lift on 113
Old Aug 30, 2017 | 05:40 PM
  #40
madsv1000's Avatar
Started weighing the rotating assembly today. Forgot to take pictures while I was doing it. Ordering bearings in the morning, and hope to have the cam ordered Monday. Only a few other things to order!
